Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
Old Jan 4, 2011 | 04:22 PM
BrothaSit's Avatar
Default Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
im working on my friends 2001 accord with a h22a4 swap. the person that did it install the motor but didnt finish up the wiring. i did alot of wiring with obd1 obd2 b and d series motor but this one is wierd. i see that the stock accord distributor harness is a single 4 wire plug. the distributor on the motor is a 2 harness (1 harness has 4 wires the other has 2) the distributor has an external msd coil with a msd ignition box. just want to know how to wire up the distributor do i have to wire it straight to the ecu or is there another distributor i can use? i searched on ht and even google and theres hardly any info about this wiring issue.
Old Jan 4, 2011 | 04:28 PM
BrothaSit's Avatar
Default Re: Need help with distributor and iacv wiring for a H22A4 into a 6th gen accord
also the iacv is not pluged in. i found a plug that is a 3 wire dont know if thats involved with the iacv
and what is this sensor? do i need it if im switch the ecu to a chipped p06?
Old Jan 5, 2011 | 03:59 PM
BrothaSit's Avatar
there has to be someone on hear that should know this
Old Jan 5, 2011 | 06:14 PM
System Lord's Avatar
http://board.accordtuner.com/showthr...to-OBD2-Accord
This may help I would call u but I'm at work
Old Jan 5, 2011 | 06:19 PM
BrothaSit's Avatar
thanks eddie but i found something better
http://www.6thgenaccord.com/forums/s...ad.php?t=27142
everybody thats looking for this info i found it so thank me later
cfwthb_94
Apr 21, 2009 07:29 AM
talonturbotsi94
Aug 18, 2007 05:23 PM
Touge Tuning
Apr 20, 2006 06:36 PM
Siegfried
Aug 12, 2005 07:21 AM
