few questions about wastegate....did search already
Old Sep 23, 2002 | 07:45 PM
_Endless_'s Avatar
Default few questions about wastegate....did search already
i got a T-28 turbo with internal wastegate. the internal wastegate gets its signal(vacuum/boost line) from the compressor housing. the internal wastegate is not adjustable and is set at only 6psi. here are my questions:
- if i were to raise the boost with my greddy manual boost controller, is it ok if i continue to use the compressor housing to get vacuum/boost signal for the wastegate? or is there other better way?
- where do you connect the mbc? is it between and vacuum/boost line and the wastegate?
Old Sep 23, 2002 | 10:00 PM
reXem's Avatar
Default Re: few questions about wastegate....did search already (_Endless_)
I believe that the MBC has to between the vacuum source and the wastegate. The way I understand it is the MBC is like a wastegate but for boost...it will gradually open as the boost increases so that the wastegate doesn't see any boost until the MBC wants it to
B16-CRX
Dec 23, 2006 06:34 PM
Teg6
Nov 17, 2006 07:20 PM
luckypon7
Jul 1, 2003 06:39 PM
blu_si
Oct 1, 2002 04:20 PM
rjardy
May 17, 2002 09:59 PM
