1996 accord drive belts?
Is there a DIY to replace/change serpintine belt and the belt below it (is it called power steering belt?)
I know the serpintine alternator belt is easy to replace but was wondering how to do the one below it and whats it really called?
my car is auto, ex, 2.2L sedan
Thanks!
Thanks!
This time belt replacement thread include info. on removing the alternator belt and power steering belt.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
I wouldn't say there is any serpentine belts as they are simple loops.....they are more like accessory belts.
The larger one is for the AC compressor and alternator (middle and bottom). The other is for the power steering pump (top).
If you can replace the AC/alt one you can replace the PS, they are pretty much identical, in terms of replacement. Just loosen the adjustment screws and then replace them. Having skinny hands and arms helps to loop the belts around the pulley.
91ex
Oct 7, 2008 11:06 AM
