Car starts then dies when i move it
Old Jan 4, 2011 | 10:25 AM
rudyndrew's Avatar
Default Car starts then dies when i move it
Well i replaced my distributor, engine harness wiring was checked out, good fuses i checked them, but will double check again. Got new/used ngk wires, bosh platnim plugs & there still good not burned black. So this morning i got up to work & it took 4x to get it on & i let it warm up a minute went to put it in gear & turned off. Went to crank it again & shut off 2 seconds after. Then i kept cranking & again turned off etc. Last nite it was running like a champ. Well i never had this problem before. I reset the ecu & nothing still. I dont get a check engine light on either so im stummped on what to do. Any1 whos had this problem or knows whats going on please help out.
Old Jan 4, 2011 | 10:27 AM
rudyndrew's Avatar
Default Re: Car starts then dies when i move it
It did this during the day yesterday, but @ night it was koo. Its weird, like it messes with me i dont know what the hell is wrong with it. I was told the main relay, but im still not convinced.
Old Jan 4, 2011 | 10:30 AM
BiG ChOr!Zo's Avatar
check out your igniton switch located in the steering column...!!!
Old Jan 4, 2011 | 10:35 AM
rudyndrew's Avatar
Ok i will, but dont you think its a lil weird cause i mean it will start sometimes then sometimes it will start then die.
Old Jan 4, 2011 | 10:36 AM
wolfsbain's Avatar
also check your battery. after a cold night i have this same problem
Old Jan 4, 2011 | 11:11 AM
rudyndrew's Avatar
brand new optima, got code 3 and 5. changed my map sensor right now and went to chang my iacv and noticed the 2 hoses werent plugged. well it doesnt have the 2 hoses that go to the iacv at all. plus i heard that if my temp gauge or temp coolant sensor is not working, i can have the same prob. is that true?
Old Jan 4, 2011 | 11:18 AM
rudyndrew's Avatar
btw. Wheres the main relay located? called a shop & they said the iacv shouldnt have anything to do with it. But that the map sensor would. Im confused on where to look for the problem.
Old Jan 4, 2011 | 11:22 AM
speedooo's Avatar
Does it bog at all? Smell like fuel? Does the radio or anything else turn off? I had a problem where the contacts on the key cylinder were corroded and when the key vibrated the car would shut off.
Old Jan 4, 2011 | 12:03 PM
Nooch's Avatar
Jesus that had to suck, ahaha. Were you lucky enough to figure that out fast? Like you accidentally jiggled the key one day and it just stalled?
Old Jan 4, 2011 | 05:24 PM
rudyndrew's Avatar
It does bog out, smells like fuel big time, but nothing else like the radio etc as you mentioned. It don't vibrate tho. Well this has been happening for 4 days now, & today @ work it didn't wanna start again, so i messed with the terminal cause i seen that they weren't all the way in & so i pushed them in, damn car started. I was scared it was gonna shut off on me cause it will die after a few minutes. It didn't die the whole to go get my son. I turned the car off, went in the in laws house to get him, came back out & the ****er started with good clean low idle the whole way home. wtf?! Would battery terminals or loose battery wires do this to my ride?
Old Jan 4, 2011 | 05:30 PM
rudyndrew's Avatar
Plus how many grounds does an EF hatch got under the hood? Just wanna know if theres any loose wires that my dumb *** friend didn't hook up cause he was the 1 wiring the car back together & i was just doing the mechanical work like axles etc on both cars. He is known to forget a thing or 2. So what should i look for? Like i said it wasn't doing this before the tranny swap.
Old Jan 4, 2011 | 05:35 PM
sirtef9's Avatar
Coil would be my first place to start.
Old Jan 4, 2011 | 05:40 PM
rudyndrew's Avatar
Coil? I just got a fresh dizzy yesterday. Ive tried 3 dizzys.
Old Jan 5, 2011 | 12:32 AM
Nooch's Avatar
Theres 3 grounds I believe: Battery, Tranny, Valve Cover. I think there's a fourth actually. Goddamnit, someone chime in and clear this up. At least check those for now.
Old Jan 5, 2011 | 06:33 AM
speedooo's Avatar
thermostat ground, that grounds the ecu.
and yes, i figured it out eventually. i was leaving work one day and couldn't get my car running. kept started it til it worked, then drove home. i realized about a week later that it was an issue with the key popping back into the second accessory position while i was driving and the car shut off...everything shut off...jiggled the key and it turned right back on. so i started carrying wd40 with me, i would spray it in the key cylinder and it would work again. that was fine until a week later i couldnt get second accessory to work at all...i held my car in start and had a friend unplug the starter solenoid and drove home 35 miles holding my key like that lol. i took the cylinder apart and cleaned it, its been good for a year so far.
Old Jan 5, 2011 | 10:47 AM
rudyndrew's Avatar
Wheres the thermostat ground located? I just seen 1 on the v/c and the 1 that goes to the negative terminal which the other end is hooked up to my bracket that holds my clutch cable. Is that 1 correct? And the starter 1 that goes to the positive terminal from what i can see.
Old Jan 5, 2011 | 11:06 AM
rudyndrew's Avatar
Ok found it. Its located between and under the throttle body and fuel rail well kinda under the dizzy. Theres 2 grounds on 1 bolt. Thats what i seen right now and it goes into the engine harness correct?
Old Jan 6, 2011 | 08:13 AM
speedooo's Avatar
yes, that's the one. Unbolt it and clean the block surface and the ground cable surface...
Absolut_D
Jan 20, 2007 09:15 AM
waterblast02
Jun 23, 2006 11:21 AM
redlines4us
Nov 18, 2005 07:37 PM
94gsr_vtc
Oct 22, 2004 12:58 PM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
