water leaks
Old Jan 3, 2011 | 01:11 PM
eg6cvchatch's Avatar
Default water leaks
Anyone know anything about water leaking into a type r, if the vents get clogged? thanks
Old Jan 3, 2011 | 02:08 PM
97CWITR's Avatar
Default Re: water leaks
Be helpful to let us know where its leaking, or which vents you're talking about...
Old Jan 3, 2011 | 02:12 PM
leaks through the driver side. i called the acura dealer and they said that after a while, the vents that drain water from the windshield get clogged and it eventually drains to the inside of your car. i found this kind of wierd. i just need to know if anyone else has had this problem
Old Jan 3, 2011 | 06:08 PM
97CWITR's Avatar
Yes, that can happen with the drains.
I've had it with my rear hatch drain getting clogged, and it can happen with the front.
Old Jan 4, 2011 | 07:36 PM
LankorDie's Avatar
Loved
Community Favorite
Find the vents and stick a wire or a pipe cleaner inside of them, or even pressurized water. Clean it out and see if that helps.
Prudz_lude
Feb 8, 2016 11:19 AM
bad 91 teg
33
Oct 1, 2011 02:34 PM
dlenoxx
Dec 2, 2010 12:05 PM
effinnwackk
10
Jul 15, 2005 05:31 AM
PatrickGSR94
Jan 13, 2005 12:21 AM
