Making harness for d16z6 swap
Old Jan 3, 2011 | 06:49 AM
CivicxTree754's Avatar
Photogenic
Loved
Icon2 Making harness for d16z6 swap
Vehicle info: 88 civic hatch dpfi obd0
I have 2 questions....1st is that im getting a (auto) engine harness froma member on here and my vehicle is manual. Will this work? Im guessing it will be 1 or 2 trans sensors left over unused?
2nd question is what all extra wires, clips, sensors will i need to source from the d16z6 harness? cause im going to the junk yard to grab all of them.
I went today and grabed the injector clip to wire in the injectors, the fan switch still attached to the t-stat housing i grabbed.
What else do I need like vtec stuff, im unsure exactly what i need. And all but the vtec wiring does it have to be from a d16z6? Like the injector wires n connectors?
If anyone can post pics so I know what im looking at when I go to the junk yard it would be perfect. Plus whats a thread without pics? I will post what i grab form the yard btw.
Old Jan 3, 2011 | 07:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Making harness for d16z6 swap
Year/make/model of your car?
DPFI to MPFI?
Converting to OBD1?
What ECU?
If your car is already MPFI and you are going to use a P28 you can retain your injectors from your engine and keep the resistor box. Or if you want to use the P28's you can grab those clips from a 92-95 Civic, 92-95 Integra and delete the resistor box.
Get the VTEC solenoid connector and VTEC pressure switch connector.
Also the fan switch plug is on the thermostat housing as opposed to the back of the block so get that connector as well. Its the same round connector as the VTEC pressure switch.
Old Jan 3, 2011 | 07:34 AM
Photogenic
Loved
Car is dpfi. 88 civic hatch. Manual And i still need to source a p28.
Old Jan 3, 2011 | 08:15 AM
crx_si-r's Avatar
I can make you a plug n play harness, pm me if interested.
Old Jan 3, 2011 | 11:40 AM
CivicSD's Avatar
use your stock CRX engine harness and just get the OBD0 > OBD1 ECU conversion harness and distrubutor conversion harness.
the vtec you simply wire it yourself to the ECU conversion harness (contains a VTEC subharness)
check rywire / boomslang / pherable / ebay
Old Jan 3, 2011 | 11:54 AM
Photogenic
Loved
I dont have a crx. I have a civic. And its def. not a si! lol
Old Jan 3, 2011 | 11:58 AM
efjones9's Avatar
jumper harnesses here n i can do tha harness for ya too
Old Jan 3, 2011 | 12:03 PM
Photogenic
Loved
PM me prices....I have mechanical skills, Its just my first swap. Im not looking to pay xxx$ for something I can do myself with a little help (because thats what this forum is for kinda) lol.
Old Jan 3, 2011 | 05:05 PM
Photogenic
Loved
Do I need a injector resistor box for this d16z6 motor? And if not how do I wire in the injectors? I was searching a found this write up (http://hondaswap.com/swap-articles/d...writeup-49557/) but its for a mpfi conversion using obd0 I will be using the obd1 ecu and jumper harness.
dudesmccool
Jan 7, 2016 01:19 PM
memorybox
Jul 4, 2006 10:06 AM
grrrrrr4me
Mar 29, 2005 08:26 PM
sharky8513
Jan 22, 2005 02:44 PM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
