normal for a cold start?? [video inside]
Old Jan 2, 2011 | 09:15 PM
em1effekt's Avatar
Default normal for a cold start?? [video inside]
does this look normal for a cold start?
was outside for like 10mins then it started raining...will try again tomorow and see if it stops after warmed up...
http://www.youtube.com/watch?v=yFDRGbL5PvU
http://www.youtube.com/watch?v=KK10vhmnsAQ
Old Jan 2, 2011 | 09:31 PM
da9h-town's Avatar
Default Re: normal for a cold start?? [video inside]
Are you referring to the smoke? If you are, then yes that is completely normal.
Old Jan 2, 2011 | 09:39 PM
em1effekt's Avatar
yeah im refering to the smoke...
i havent drove the car for a couple of days so i got kind of freaked out =0
Old Jan 2, 2011 | 09:45 PM
da9h-town's Avatar
Naw perfectly normal, the heat will cause it to smoke when its real cold outside.
Old Jan 2, 2011 | 09:49 PM
em1effekt's Avatar
okaay..thanks man
::relived::
Old Jan 2, 2011 | 10:41 PM
SeanK325's Avatar
how cold was it outside? what does it smell like? is it blue or white?
Old Jan 3, 2011 | 09:57 PM
em1effekt's Avatar
it was about 43 degrees...
it did it a bit less this morning..let it warm up..and when i go to work..no smoke at all =] good right?
Old Jan 3, 2011 | 10:15 PM
em1effekt's Avatar
been watching other videos on youtube...begining to think its a bad turbo???
Old Jan 4, 2011 | 07:13 AM
mr ihashatch's Avatar
some of it is condensation from being so cold, my eg does the same thing. It's basically the equivlant of you breathing in cold air, it creates the white cloud.
Old Jan 4, 2011 | 09:58 AM
SeanK325's Avatar
It does sound like just the effects of cold weather. Unsure about a bad turbo.
Old Jan 4, 2011 | 02:11 PM
AutoXer's Avatar
It's tough to tell from that video. Can you get one in the daylight? If it's cold out, you will see water vapor on startup. If it's really cold, you will see the exhaust vapor even when the car is warmed up.
Old Jan 4, 2011 | 06:41 PM
em1effekt's Avatar
ill get a video of it in the day tomorow morning...
this morning it didnt really smoke that much
Dat1BVtecN
Jan 5, 2009 08:45 PM
MADBADGER
Honda S2000
18
Dec 18, 2007 05:02 AM
pr0gress
Aug 16, 2005 12:21 PM
1hotcivicSi
Apr 24, 2004 06:40 AM
MJ23FE
Oct 25, 2002 11:31 AM
