View Poll Results: Which Intake Mani for All Motor CRVtec? Not a dd.
Victor X
37.50%
Skunk2 Pro
43.75%
STR
0%
Other - Please leave comment for which
18.75%
Voters: 16. You may not vote on this poll
which intake mani to use...
Old Jan 2, 2011 | 03:25 PM
stevieriot's Avatar
Default which intake mani to use...
What intake mani should i run? I have a skunk2 pro series IM, a victor x IM, or theres an str on here for sale im interested in... not a daily driven car...looking to build a new, higher compression block, get a new tranny, and pro3s when i finish the next block... so this is just about the intake manifold...
Setup:
CRVTEC
GSR Head:
70mm STR TB
Edelbrock Victor X Intake Mani
Injen Intake with velocity stack out headlight
BDL Fuel Rail and B&M FPR.
DSM 450cc injectors
OmniPower High Compression Flat Faced Valves
Supertech Valve Guides
Supertech Valve Stem Seals
Skunk2 Pro 2 Cams
BDL Cam Gears
Skunk2 Pro Series Springs
Big Tube Tri Y Header
B20z Block
Stock Sleeves
84.5mm 11.5:1 Wiseco Pistons
Eagle ESP H Beam Rods
ARP Rod Bolts
Honda Bearings
Stock Crank
Stock Oil Pump
Stock Water Pump
Girdle
GSR Oil Pan
Cometic Head Gasket
ARP Head Studs
LS Tranny
8 Lb Flywheel
Stage 2 Clutch
Custom Oil Breather/Catch Can
Old Jan 2, 2011 | 03:33 PM
newtype_33's Avatar
Default Re: which intake mani to use...
victor x........
Old Jan 2, 2011 | 05:16 PM
93egSLEEPER's Avatar
Originally Posted by newtype_33
victor x........
x2
anything larger then a 1.8 needs the larger plenum, more air and shorter runners.
Old Jan 2, 2011 | 05:33 PM
00Red_SiR's Avatar
All Motor Mentor
Hands down, Skunk 2 pro series. All the recent testing has clearly shown the ITR style intake manifold to be superior on a 2L build. The Victor X just doesn't perform and shouldn't be used on anything that isn't boosted or used for drag racing exclusively. Better results will come from a ported IM and a custom intake like the Endyn IM is probably the best way to go for best overall power.
Old Jan 2, 2011 | 06:19 PM
racer034life's Avatar
I wouldn't say the victor X doesn't perform. But I would say for your motor build it would be over kill. The sk2 pro will work better for you in the long run and through the powerband.
Old Jan 2, 2011 | 10:27 PM
stevieriot's Avatar
This is a drag only motor. So I'm not worried about streetability. Looking for a mani I can use now and in future when I finish my next block. Gonna run a sleeved and stroked block, 95x86 with 14:1 pistons... Then upgrade to pro3s... I was leaning towards junking the skunk2, cuz I feel for a drag motor, its jus too small. I'll look into the endyn. I was jus seeing what else there is for a reasonable price that will give me more power... Right now the victor x is ported for a 76mm tb. Skunk2 is prob factory, untouched (traded my buddy a diff victor x for it, he needed a bigger mani for turbo).
Old Jan 2, 2011 | 10:32 PM
949's Avatar
949
sorry for the thread jack, but will the victor x work on a D series engine?
Old Jan 3, 2011 | 04:53 AM
00Red_SiR's Avatar
All Motor Mentor
In that case, go with a custom Endyn unit or the Victor X.
If you can find a Victor X that is made for a D-series engine, then I guess it will "work".
Old Jan 3, 2011 | 11:15 AM
OH_1fstgsr's Avatar
I pick other. Why? You have spent a bit of time and a ton of money on your set-up, why go cheap on a manifold.
I have GSR manifold that has been reworked and is able to out flow a ported Skunk2 Pro and not lose air velocity. So maybe a custom stock manifold, I went this route because I want my low and mid range power back. Not ideal for drag but and option.
Other options, the Magnus and one of BMC's.
All of the aftermarket manifolds are designed around trying to work well on a range of set-ups.
The other question you need to ask yourself is the cost of a Skunk Pro or Victor X plus porting and reworking, about $500, is nearly the same as a high dollar custom manifold.
With the Bore, Stroke, compression and Cams your running I would think something custom would yield the best results.
Old Jan 3, 2011 | 04:55 PM
N/A's Avatar
N/A
Purpose Built
https://honda-tech.com/forums/showth...ormer+manifold
Old Jan 4, 2011 | 09:04 AM
josephcmiller2's Avatar
Don't choose an IM until you read the following:
http://www.team-integra.net/sections...?ArticleID=466
You don't choose an IM based on how much power you want to make, you choose an IM on where you want to make the power. Size is important for bigger numbers, but if you pick an IM for the wrong range, it can have a negative air flow effect in the RPM range that you are driving.
BigBlock22
51
May 20, 2013 06:12 PM
OrangeTeggy
Mar 8, 2011 07:46 AM
91tegrsjg
12
Aug 29, 2010 05:48 AM
GSR_hatch936
May 23, 2010 08:53 AM
R3Ycivic
66
Jan 24, 2010 01:04 PM
