Why is there a hole in this transmission?
Old Jan 2, 2011 | 02:42 PM
fleabag's Avatar
Default Why is there a hole in this transmission?
Also, should this d-series transmission be shipped on a pallet or is there a way to properly package this thing and still ship via Fedex ground/UPS ground?
Old Jan 2, 2011 | 02:44 PM
scrooge's Avatar
Default Re: Why is there a hole in this transmission?
your starter goes in that hole.
Old Jan 2, 2011 | 02:47 PM
fleabag's Avatar
whats that gear on the right then?
Old Jan 2, 2011 | 02:50 PM
HondaPartsHero's Avatar
Technical Hero
Old Jan 2, 2011 | 02:58 PM
fleabag's Avatar
Originally Posted by HondaPartsHero
vehicle speed sensor
I thought the VSS was not only a much smaller gear but also inside of the transmission. Why would the VSS attach to the flywheel if you're trying to measure vehicle speed?
Old Jan 2, 2011 | 03:01 PM
Targa250R's Avatar
be professional
There is no "gear" pictured. The open hole in the upper center of the photo is for the starter. The hole in the lower right side of the photo is where the left axle is inserted into the differential.
It doesn't attach to the flywheel. There is no flywheel in the photo. The VSS enters the transmission case and is driven by a gear pressed onto or machined into the differential housing.
Old Jan 2, 2011 | 03:07 PM
fleabag's Avatar
when I was talking about the part where the axle goes, I thought he said that's where the VSS comes out of or something like that. I'm not that familiar with FWD transmissions which is why I hadn't even considered where the axle for the left wheel would go in this setup.. Thanks for the clarification.. Now onto the next issue which is, how is this transmission going to be shipped? How does one ship a transmission in a box? Peanuts? Bubble wrap?
Old Jan 2, 2011 | 03:39 PM
Targa250R's Avatar
be professional
Drain transmission, strap to small wooden pallet, wrap with shipping plastic. This is what most automotive salvage yards do.
Or, drain transmission, wrap with shipping plastic, and pack into sturdy double-walled cardboard box with foam-in-place blocks or layered corrugated blocks. This is what some transmission rebuilding services do.
Azhar Amin
Honda Civic (2001 - 2005)
Feb 2, 2019 01:04 AM
crxjarred
Transmission & Drivetrain
Jul 12, 2014 01:21 AM
