Valve Cover
Torque the valve cover fasteners to 7 lb-ft. Do not overtighten; they will snap off if you try to crank them down.
For RTV sealant, use Hondabond, Hondabond HT, Honda Ultra Flange Sealant, or Permatex Ultra Grey. I recommend Hondabond HT as it's the easiest to work with, but the others are fine. Just use a small dab on each of the four sharp corners of the valve cover gasket around the camshaft humps.
Figuring Bubba had over-torqued all the nuts when he put it back together, I decided to remove ALL the studs and replace them with new, grade 8 studs. Don't want that happening again.
And yes, I used a torque wrench.
Si_chRis
18
Jul 5, 2006 05:25 PM
