Suspension & Brakes Theory, alignment, spring rates....
Stuck proportioning valve? No pressure to RF/LR brakes.
Old Jan 2, 2011 | 01:32 PM
Anticlimactic's Avatar
Default Stuck proportioning valve? No pressure to RF/LR brakes.
I just picked up a '90 Civic Si, and it has a DA rear disc conversion, and still has the stock Si 13/16" master cylinder/booster.
No matter what we've done, bleeding the brakes, bench bleeding the master cylinder, and checking literally ALL of the lines for flow, the front passenger and rear driver side calipers aren't getting any pressure. We've air tested the lines to each, and the line from the master cylinder to the proportioning valve, and they all checked out fine.
Since the problem corners both run through the top of the proportioning valve, I'm thinking either something may be blocking it, or maybe it's stuck. I've read that some proportioning valves, as a safety feature, close when a line is blown. Unfortunately I don't know the history of the car, so it's a possibility, and I don't know how the swap was done. Has anyone had any experience with this issue, or know of a way to fix it? I'm thinking I may have to replace the valve, but I'm trying to be sure this is the issue.
We've spent all weekend just trying to figure out what the issue is, and since we've gone through the MC and lines, and still have only two functioning calipers, it's frustrating. Any insight is a huge help. Thanks!
Adam
jetspeedz
Suspension & Brakes
Sep 18, 2012 04:01 AM
airforce21
Suspension & Brakes
Jul 17, 2011 02:48 PM
go2sleep
May 27, 2005 09:29 AM
jdm92accord
Jan 31, 2002 08:15 AM
