are d series rod bearings the same as ls rod bearings?
Old Jan 2, 2011 | 11:57 AM
phaphon's Avatar
Default are d series rod bearings the same as ls rod bearings?
i'm replacing rod bearings on my ls, and i need to know if i can order the single cam rod bearings.For my ls block with ls rods...the reason being is that i cannot find cheap rod bearings for my ls on ebay.
Old Jan 2, 2011 | 12:13 PM
4dregDC's Avatar
Default Re: are d series rod bearings the same as ls rod bearings?
No they r not da same I have a d-series wit b20 rods n had to use ls bearings my d bearings werent compatible
Old Jan 2, 2011 | 12:16 PM
phaphon's Avatar
ok thanks
Old Jan 2, 2011 | 01:19 PM
apexi_rsx's Avatar
Rod bearings for D series have a different part number than rod bearings for B18B... however they do work. I know that a lot of ppl here use B18b Bearings on their D series rods when the d series rod bearings are not available.The only different is that the B18b bearing is a lil bit wider...
Old Jan 2, 2011 | 01:30 PM
4dregDC's Avatar
Kool now i knw, any machine wrk needed or is it a straight fit
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
soodominican
Feb 21, 2009 04:06 PM
EGhatchLSV
Feb 2, 2009 02:16 PM
jarvis199
Dec 11, 2007 12:42 PM
VtecnTurbo
Oct 8, 2006 07:16 AM
