95 civic DX B18 Swap: Smoking
Old Jan 1, 2011 | 09:51 PM
atlballazz06's Avatar
Default 95 civic DX B18 Swap: Smoking
have a 95 civic coupe with a b18 swap. There is light white smoke coming out of the tail pipe. Then my car started skipping when I step on it. So I did a compression test to see if the head gasket our something is gone and while I was doing a compression test when I took the compression tester out after cranking the car cylinder 2 and 3 have smok coming through the spark plug hole. I have 180 psi in all 4 cylinders and I just really change my plus and wires about 5000 miles a go. The CEL is on its throwing codes 6 and 7 does anyone know whats going on.
Old Jan 2, 2011 | 12:03 PM
Default Re: 95 civic DX B18 Swap: Smoking
I know someone knows about this
Old Jan 2, 2011 | 12:25 PM
95ProjectEJ1's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jan 4, 2011 | 07:54 PM
thanks but I know what the cel codes are I just need to knower why its smoking the way it is. Now when I turn it off when its hot it doesn't wanna crank back up.
platoonsmoke1
10
Dec 9, 2014 10:11 AM
94_civic_dx
Jul 17, 2012 07:21 AM
scooby_dooby
Nov 21, 2003 02:03 PM
