Detailing Auto Detailing and Concours
How To: Eco Waterless Wash Your Car
Old Jan 1, 2011 | 03:28 PM
DA JeLLie's Avatar
Default How To: Eco Waterless Wash Your Car
Take a peek at this video I put together about waterless washing. This method will remove dirt, water spots, bird droppings, dead bugs & road grime. While using this technique remember the following tips:
1. Spray plenty of wash solution on the vehicle.
2. Work one panel at a time.
3. Wipe solution off lightly. (no pressure)
4. Turn towel to a new side often.
5. Get a new towel when needed.
6. Buff off haze.
Instructions Listed below.
http://www.youtube.com/watch?v=-DlSra-i_jQ
1. Start with a mildly dirty car (dust is okay, mud is not)
2. Pull your car into a shaded area.
3. Put your waterless wash solution in a spray bottle (or pump bottle like shown)
4. Start spraying an upper panel of the car (work top of the vehicle down)
5. Use a clean microfiber cloth, and gently wipe the solution away. (DO NOT wipe over dry areas)
6. Buff off haze.
7. Repeat until entire exterior is clean. (solution works on windows & wheels as well)
Items Used in Video
1. Chemical Guys Eco Smart Waterless Wash – $20
2. Pump Sprayer (available at Lowes) – $8
3. ADS Premium Microfiber Towel – $1.20/ea
Old Jan 2, 2011 | 08:22 PM
Ozne99's Avatar
Default Re: How To: Eco Waterless Wash Your Car
Nice. I see butt crack at 2:06
Old Jan 4, 2011 | 01:22 PM
PaladiNSX's Avatar
I just cant wrap my head around the idea of a waterless car wash. If you wipe a rag across a body with loose dust particles, how are you not swirling the grit around your paintjob?
Old Jan 4, 2011 | 10:45 PM
atxspK's Avatar
Just try it PaladiNSX. I use optimum no rinse and it works great, just use two bucket method, grit guard and nice microfiber/lowes grout sponge.
One tip, I tend to soak up a lot of ONR solution, wipe the area and squeeze the sponge so solution comes out and the dirt goes with it (if that make sense).
Old Jan 5, 2011 | 06:58 AM
DA JeLLie's Avatar
You are using the solution to help lift the dirt off the paint of the car. With light to no pressure, you are removing the dirt, not swirling it around. You also have to change towel sides often, and change to a new towel often as well.
Old Jan 5, 2011 | 07:09 AM
Vew's Avatar
Vew
I was skeptical when I first tried this type of system, and I'm a big detailing nut. I use ONR. As long as you follow the rules/steps correctly, there is little risk. It's arguable that it's safer than traditional washing. You know you're doing it right if the "dry towel" never becomes dirty.
Old Jan 5, 2011 | 12:28 PM
DA JeLLie's Avatar
I will have a separate video for rinse-less washing. They are similar but not the same.
Bxjay16
Paint and Body
Jan 2, 2012 07:21 PM
asocallocal
Paint and Body
Oct 22, 2009 08:27 AM
Dat Fiyahhh
Honda Civic (2006 - 2015)
Feb 14, 2008 08:32 PM
vtek9
Jun 23, 2007 10:37 PM
leechungsr
Oct 5, 2001 04:55 PM
