High beam not working and blue dash light is on
Old Jan 1, 2011 | 12:34 PM
pjean_07's Avatar
Default High beam not working and blue dash light is on
I just installed a hid kit on the high beam and the next day one side was not working anymore. I cheked the bulp and the ballast and its working, ive cheked the fuses (10A engine bay fuse box and 7.5A under dash fuse box) ive cheked both wire that goes to the high beam plug and i found that the ground is good but there is no power on the red/black wire. Also ive found that when my LOW beams are on you can see a very small shadow of the blue high beam dash light.. it was not doing that before the hid's... can someone give me any info on how to troubleshoot this? i have a multimeter but dont know how to use it..thanks
Old Jan 4, 2011 | 07:08 AM
turboteg2nv's Avatar
Default Re: High beam not working and blue dash light is on
Put the stock bulbs back in the high beams and test to see if they work.
Old Jan 4, 2011 | 09:32 AM
PiNoY Ep3 SI's Avatar
What kinda car is it ep or rsx? If it is an ep what year 02-03 or 04-05? I saw this problem with an 05 ep and it turned out to be one of the fuse's were blown.
Old Jan 4, 2011 | 01:45 PM
cloumep3's Avatar
Had similar problem, it turned out to be a bad ballast. Bought and installed new brand and don't have a problem since.
Mr. Prelude
May 12, 2011 03:16 PM
not-a-stang
Apr 9, 2008 07:50 AM
Chitown DC5
Nov 18, 2007 12:37 PM
civicsir924
10
Jun 30, 2005 06:22 AM
DC231 Sean
Jul 27, 2004 07:49 AM
