ef sidemarker install
ok so i have my sidemarkers installed on my hatch my question is the wiring? how do i wire them up to come on with my running lights and stay on then also blink with blinkers every write up i see shows three wires mine has 2 theres the running light wich has 2 and blinker which has 2 so plz help me out ht its a 91 teal civic si thanks
This is for sidemarkers to only blink when turn signal is enabled (jdm)
This is for sidemarkers to blink when turn signal is enabled ... but will turn on constant with headlights on, blinking in opposite with the turn signal (usdm)
Nice idk y but that pic up there says blinker lights have 3 wires mine has 2 there's two light bulbs in my corners and each have two wires I'm stumped
jut get a light tester turn your turn signal light and test each wire for power but if it has two black is usually ground i installed some in my boys 89 prellude hella easy to wire up
EF_World
14
Oct 12, 2010 07:06 PM
Stephen90Si
13
Aug 16, 2009 03:18 PM
4wd, bulb, california, civic, ef, honda, install, marker, moorpark, sale, side, sidemarker, sidemarkers, wiring, write
