b18c1 600hp or bust lol
well I have been kicking around what to do another built block or a stock one, and decided we will go for the stock gsr block and max it out where it stops lol.
I know about the reliability, and ringlands, and this and that but thats not the pusrpose of this at all. we just wanna show what you can actually get from a stock block, and how long it will last.
ill have around 800 bux invested in this project due to having everything i need already except for the block wich will be on its way to my door step soon.
build when done will consist of
1989 crx si
stock gsr long block
t1 trigger
m& pro14 with cop
eagle cam gears
aeromotive fuel rail
rc1000's
aeromotive a1000 pump/with street voltage regulator
aeromotive regulator
dss3.9's
synchrotech b series tranny with liberty cuff, and carbon synchro's
will be tunes on e85
aem-ems
hassport mounts
ge head studs
ge gasket
redline topmount mani
pte67mm turbo
38mm gate
50mm blow off
cx racing i.c/to be upgraded to a precision 600hp cooler
2.5" i.c. piping
70mm throttle body
excedy twin disk
the last time on a stock block we managed 500hp@26psi
goal is 600hp this time
here is some pix of the crx with my busted *** built block out of it
thats pretty much it
1989 crx si
t1 trigger
m& pro14 with cop
eagle cam gears
rc1000's
dss3.9's
aem-ems
hassport mounts
ge head studs
ge gasket
pte67mm turbo
38mm gate
50mm blow off
2.5" i.c. piping
70mm throttle body
excedy twin disk
give me till march lol
block will be here within the next 2 weeks hopefully then put it all togather, and wait for newer parts then a trip to kansas city for tuning
so what are you doing different from last time? how long did the other stock block run? I'm in the process of doing a stock bottom end lsvtec build. only hoping for 350 on E85. When i get my other block built ill prolly try to push it to the limit just out of curiosity myself.
same stock block
we are going to tune it out, and now im on a 67mm pte makes a little more power than before
we tuned it midly last time to be honest kept the base at 40psi we will probly go up to 70-80 this time to reach our goals.
after its done ill switch to id2000's/ 6765 maybe a weldon 2025 as well.
my main plans are to have a running motor to put the new stuff around then next winter pull the block and have it built by the timke we drop her back in we will be ready for 800+
donno we will see my tuner seems to think its not an issue. the main differance this time is i will not be driving it on the streets at all to try and prolong the motor.
dantamparacer
Jul 27, 2009 11:52 PM
