For Sale and WTB - January 2011
All parts are to be ITR related or it will be removed.
All items for sale must have a price posted or the item will be removed.
If someone posts a FS price and you disagree, don't buy or comment on it.
Anyone posting multiple items please try to use one post.
Don't quote a post with all the pics repeated, or don't quote your own post.
Comments need to be through email or PM.
2011 Goodies !
Matte Black CE28s 16x7 42 offset 5x114.3 - basically bnib - $2200
Polished Regas 15x7 - 40 offset - 5x114.3 - $1400
Work RSZ-R's - 15x7 42 offset - 5x114.3 - $1300 ( I have 2 sets - same specs )
Work RSZ-R's - 16x7 - 42offset - 5x114.3 - $1500
Matte Black SSR Type C's - 16x7 42 offset - 5x114.3 - $1600
F1 spec III sets ( little wider than the small ones ) - $400 - no rails
JDM ITR Front seats - Minty - Pass seat has the adjustment ***** to raise & lower the seat - $700 ( look identical to the US ones )
ITR rear seats - $200
Full Black Interior (non itr but may help if you are putting one back together )- prefer local pickup - $325 w/ stock teg seats
UPDATED 1-24-11
561-346-5421
A few things I have for sale everything is priced without shipping.
open to trades and offers. thanks
USDM ITR final drive...less than 5k, includes gear ring and countershaft- 250
USDM ITR air intake plumbing less than 5k- 50
custom test pipe with 02 hole threaded- 50
P73-003 ECU... I believe its a jdm ITR 97-99 ecu- 200
98-01 oem side mirror- 100
complete gsr door mint-100 each including everything
ITR oem tie bar-60
gsr climate control-50
98 itr climate control... no cf but amber lights-100
itr shift linkage-100
jdm front replica grill-50
jdm front oem passenger side fender liner-70
mint gsr dash-50
gsr hatch with shocks-50
JDM ITR side markers with bulb- 50
JDM itr front bumper with lower grille cut out in PY-will trade for non cut bumper
00 tail lights---pending
rear center piece--- pending
jdm front oem itr passenger, driver fender---sold
gsr leathe door pannels---sold
gsr cluster-106k---sold
What I need will only trade for
CF ITR interior pieces
ITR armrest with or without badge
205/45/16 4 or 2 tires
oem jdm front bumper
oem jdm front lip
red lug nuts
oem 00-01 cams
valve cover acorn nuts
561-346-5421
ITR oem tie bar-60
mint gsr dash-50
oem jdm front lip
red lug nuts
oem 00-01 cams
few parts for sale i have
jdm header $200 +shipping
2001 floormats $120. +shipping
2001 tail lights $200 +shipping
jdm gunmetal 16'' wheels $600 sold
please pm, paypal only.
thanks
thanks
spoon n1 dampers itr spec
$900shipped.. 25K miles on them, drivers side shock is blown (but still works), the other 3 are okay. spring rates are 16k F / 10k R, ITR Spoon N1 Coilovers
spoon p73 ecu- 750shipped
TEXT ME FOR A QUICK RESPONSE - 305.733.7331
NO TRADES! NO TRADES! NO TRADES! NO TRADES! NO TRADES!
15x7 +40 5x114.3 black Slipstreams w/ Bridgestone RE-11 tires - $650
- 100 miles on tires, 205-50-15
CT Engineering Icebox, mint - $175
RR/AutoX ITR brake package - $150
- 2 new autozone blank front discs, new front Hawk HP+ and rear HPS pads
VTEC solenoid - $40
cargo cover, mint - $40
USDM airbag - $40
Rear B Series T mount bracket - $25
VTEC solenoid - $40
USDM airbag - $40
FS
Built ITR head - $1600
ITR Trans with 4.9 FD - $1600
Spoon SW388's - $1400
Mugen front strut tower bar - $250
Stock ITR trans - $900 might need 3rd gear syncro
I'll update later with pics and additional items found here
http://www.hondamarketplace.com/show....php?t=2827914
FS:/Possible trades:
listed asking prices DO include shipping, however DO NOT include paypal fees but PM me im always open to trades or even best offers if you're buying more then one piece, Email is SDinHD@gmail.com if you want pictures or have offers. sorry just cant load that many pictures
OEM USDM 2000 ItR/PR3 cylinder head, just hot tanked, 100% complete w/ V.C., USDM ItR cams, vtec solenoid, ItR I.M., IAT sensor, IACV valve, OEM 62mm ItR TB with TPS and MAF, includes all IM & TB studs, bolts and nuts - $1200 shipped
Holley Fuel Rail(anodized red) with Holley FPR(silver) Rail retails for $250 and FPR at $200, so half price - $225 shipped
BNIB JE/SRP Pistons, 81.5mm, 6.4cc dome, 30mm height, so 11.6:1 CR on an ItR, part #149213 - $325 shipped
BNIB Eagle 5.430" GsR/ItR connecting Rods, part# CRS5430a3d - $300 shipped
Brand new MSD 8.5mm Ignition wires, Part #32349 - $95 shipped
BNIB MSD SCI-L ignition control box, Part #6320 - $175 shipped
BNIB T1R voltage stabilizer, part# 40000-VP2-P - $75 shipped
Brand New MSD Pro red cap, part #82921 - $50 shipped
Magnecore B18C5/B series Ignition wires - $40 shipped
Crower flat faced valves - $60 for 16 valves shipped
OEM '01 ItR Valves, IN and EX - $180 shipped for all 16
OEM GsR valve springs (dual intake/ItR intake springs) - $100 shipped/set all 24
OEM '01 USDM ItR P73 rods and pistons - $150 shipped/set
OEM ItR oil cooler with hard water line, o rings, thermostat, thermo switch & full housing - $200 shipped
OEM '01 ItR crank pulley - $80 shipped
OEM ItR chasis/engine/PS rack performance bar/rod - $35 shipped
OEM USDM ItR rear trunk/frame end performance rod - $55 shipped
OEM USDM ItR front lower sway bar w/ bushings and end links, 24mm -$140 shipped
OEM ItR TDC sensor, works fine just replaced since it is plastic - $30 shipped
OEM ItR/DC2 timing belt tensioner, bolt and spring - $40 shipped
OEM ItR rear and drivers side motor mounts and L,R rubber mounts - $140 shipped for the 4
OEM DC2 driver side fender liner and engine under cover - $40 picked up for both
OEM ItR front Lower Control Arms w/ bushings - $100 shipped for both
OEM ItR Rear trailing arm bushings - $40 shipped
OEM ItR rear toe/compensator arms - $50 shipped
OEM ItR front compliance bushings - $75 shipped
OEM USDM drivers side axle - $100 shipped
OEM USDM ItR rear 22mm sway bar bushings - $15 shipped
OEM USDM shift linkage bushing - $15 shipped
OEM ItR/DC2 used thermostat - $15 shipped
OEM ItR/DC2 Oil dipstick - $15 shipped
OEM ItR 1" Brake master cylinder - $100 shipped
OEM ItR Clutch master cylinder - $55 shipped
OEM ItR Clutch slave cylinder - $25 shipped
OEM JDM ItR front 25mm sway bar bushings - $15 shipped
OEM JDM front bumper nighthawk black pearl - $150 picked up
OEM JDM ItR front lip/chin spoiler, '01 ItR NBP color, needs re-spray probably - $150 picked up
OEM '97 USDM ItR CW lip/chin spoiler slightly cracked on front right corner but fixable - $200 picked up
OEM '01 ItR P.P bolts(6) - $15 shipped
OEM '01 ItR F.W. bolts(8) - $15 shipped
OEM '01 ItR Main bolts (10) - $25 shipped
OEM '01 ItR Head Bolts (10) - $50 shipped
OEM '97 USDM ItR Fuel Pump - $75 shipped
OEM USDM ItR Cat. Conv. (maybe a AFR installed and then re welded?) - $120 shipped
DC Sports JDM 4-1 header (dents) - $100 picked up
Apex I WS2 Catback(no axle back/muffler section) - $180 picked up
ACT lightweight flywheel - $120 shipped
ACT clutch kit - $120 shipped
CompTech CAI with filter, complete - $250 shipped
ApexI VAFC w/ all harness and manual - $110 shipped
OEM front 6-1/2" speakers and tweeters - $70 shipped
Kenwood KDC-138 in dash CD player - $40 shipped
BNIB OEM ball dust boot for 92-01 Integra, 51225-SR0-A01 - $15 shipped
BNIB OEM tie rod boot for 97+Integra and more, 53546-S84-003 - $15 shipped
BNIB OEM GsR Ex. manifold gasket, 18115-P72-003 - $15 shipped
AutoMeter Pro-Comp oil pressure guage, 0-100psi - $20 shipped
BNIB PPi PCX-2200(1600w rms) real 2ch amp, hand built in Tempe AZ - $400 picked up
BNIB PPi PCX-480(1280w rms) old school 4ch comp. 'cheater' amp - $350 picked up
PPi PCX-250(400w rms) 2ch comp. cheater amp hand built like the other 2 - $150 picked up
MB Quart PVF-213 5-14" components with the real german PTF40's - $200 shipped
OEM IiR PS pump, belt,line and reservoir - $150 picked up
Full OEM ItR AC System w pump/belt - $450 picked up
PRICE LOWERED TO $350!!!!
Brand New
"Real Deal Holyfield" Mugen Speedometer. What you see is what u get. Asking $420 Located in Brentwood Email - serspecvspeedca@hotmail.com Cell - 9255849982 Daniel
Brand New
For Sale:
JDM OEM Oil Cap (Chrome with minor scratches from use)... $30
OEM ITR Valves, Valve Springs & Retainers (approx 40k on them) ...$150
OEM ITR Leather Wrapped Steering Wheel & Air Bag... $75
OEM ITR Exhaust Manifold...$50 (shipping will be a beast on this :/)
Helms Manual for 98-00 Honda Civic & Haynes Manual for Integra..$40
OBD1-OBD2 Jumper Harness...$75
Red Polyurathane Bushing Inserts & Stock Drivers Mount Polished (Comes with street & race insert)...$50
Mugen Front & Rear Strut Bars (sticker on the rear is a little off center)...$400 pair
REAL Mugen Oil Cap...$60
REAL Mugen Radiator Cap....$35
REAL Mugen Gun Metal Shift **** with original box...$50
JDM Clock block off Plate...$25
MINT*OEM ITR Optional Checker Pattern Rear Floor Mat...$375
OEM ITR Radio with Code... $100
JDM Arm Rest Delete with 98R Badge & mounting bracket...$100
New OEM ITR Oil Pump (still in Box, never opened)...SOLD
Comptech Rear Lower Tie Bar (Annodized Red) ...SOLD
Cusco Master Cylinder Brace (Made for USDM Vehicles. NOT JDM=No modification Required)....SOLD
Email will get the fastest response.
Jaredreyes83@gmail.com
1st gen oil cap, kinda dirty in the pictures...will be cleaned up good before sale.
$85 shipped
Mugen OBD2a ECU. part# 37820-xj1-oono the cover is a little beat up but it can be cleaned. i just didnt want to chance messing up the sticker.
$650
Mugen 1st gen 4-2-1 header. This has been modified to a 2.5 inch collector. Sorry this is the only pic that i have since its still on the car.
Bottom IS dented.
$300 OBO
Buddy club bucket seat. Only been used for about 1 month size medium. BOTTOM SEAT CUSHION IS INCLUDED, JUST NOT PICTURED. $325
MOMO Street racer seat, This seat is a few years old but has barley been sit in. dirty in the pictures but is in almost mint condition. no damage at all. $225 picked up.
Energy suspension rear trailing arm bushing for EG/DC BNIB $30
$85 shipped
$650
Bottom IS dented.
$300 OBO
Sprint Hart CPR
16x7+40F 16x8+37R 5x114
$2,000 FIRM
$2,100 Shipped
the wheels on my R
[/QUOTE]
and more cpr here!!!http://hondamarketplace.com/showthread.php?t=2873813
$2,000 FIRM
$2,100 Shipped
the wheels on my R
[/QUOTE]
Description: Desmond RegaMaster EVO 16x8 +35 5x114.3
Condition: Used with brand new valve stems
Price: $1600 Picked Up or $1750 Shipped
Click here for more pictures
Description: Desmond RegaMaster EVO 16x7 +35 5x114.3
Price: $1400 Picked Up or $1550 Shipped
LHD CF Driver Vent
LHD CF Ashtray Housing,Ashtray,Cupholder
LHD CF Shift Plate "one broken tab underneath check in picture
Sold!
acura integra 94-01 JDM Armrest Delete New Only test fit to car
$55.00 Shipped
Sold!
$55.00 Shipped
