Check Engine Light Flashing - '03 Odyssey
Flashes ten times when I start up. Google searchng didn't tell much, except maybe it's related to an air intake temp sensor.
EX model, never had any issues, about 82k on it.
Any other help H-Ters?
1) Bump
2) Maybe a little more info if it'll help you answer my question; Ever since the check engine flashing started, slight rattle can be heard on passenger side under the hood. It goes away once you reach around 15mph-20mph or 1500rpm's-1800rmps. I assume the alternator and power steering are in the same area. Maybe a loose belt?
http://www.buzzle.com/articles/check...-flashing.html
are you sure its the CEL and not the maintenance light (dumb question i know)? i know after a certain interval, it will blink to alert the owner to do oil changes etc.
usdmEHboy
Feb 18, 2007 07:34 AM
