leaky oil pan 94 del sol turbo
Old Dec 30, 2010 | 04:20 PM
miller502's Avatar
Default leaky oil pan 94 del sol turbo
i cant figure it out. oil is leaking around the base of the oil pan. i have check the oil pan bolts and nuts several times, and only one or 2 on the back side of the block back out, but the others stay tight, but it keeps leaking. and im loosing like a quart a week. if any one has any thoughts or suggestions id be open to any advice. but i dont know any smartass answers.
Any ideas what to do people ?
Old Dec 30, 2010 | 04:27 PM
fritter critter's Avatar
Default Re: leaky oil pan 94 del sol turbo
tried a gasket?
Old Dec 30, 2010 | 05:46 PM
miller502's Avatar
yeah , put a new gasket in upon the turbo install
Old Dec 30, 2010 | 07:05 PM
Coupez6's Avatar
I have the same problem but I gotta get a new gasket..Did u use sealer too??
Old Dec 30, 2010 | 07:49 PM
miller502's Avatar
yup
and still leaks , does your leak right under the oil filter on the pan, then it hits the axel when your driving and slings it every were
Old Dec 30, 2010 | 08:09 PM
farfrumugen's Avatar
if your pvc system isn't working properly you could be pressurizing your system and forcing oil out. did you use a torque wrench and properly torque the bolts? to tight can cause leaks as well.
i had a pan that was leaking and leaking and i couldn't figure it out. then one day i was under the car and i seen an oil drop seep through the pan itself. i started poking around and their was rust under the paint and it was bad enough that the oil was seeping through.
just a few ideas.
adam jeffery
Old Dec 30, 2010 | 08:47 PM
miller502's Avatar
it isnt the pvc system , an it cant be rust and i've cranked the bolts down, whats the propper torque for em ?and its like around the the oil pan on the back side where u bolt to the bottomw of the block
Old Dec 30, 2010 | 08:49 PM
KBG Indey's Avatar
warped oil pan?
Old Dec 30, 2010 | 08:58 PM
miller502's Avatar
i dont think so cause it didnt leak on the original set up. so why leak now if it was warped
Old Dec 30, 2010 | 09:10 PM
00PhillySi's Avatar
That right there is your problem. There are torque specs for things for a reason. You need to replace the oil pan gasket again, but this time follow the recommended torque spec for the bolts, I believe a common torque spec for oil pan bolts is 8-10 ft/lbs.
Be sure you DO NOT crank down on the bolts, this pinches the gasket and creates leaks.
Old Dec 30, 2010 | 09:18 PM
miller502's Avatar
by your definetion" crank down " would it look like it forcing the gasket out from between the oil pain and the block ?
Old Dec 30, 2010 | 09:21 PM
00PhillySi's Avatar
If it looks like its forcing the gasket out the sides, its definitely too tight, and once its too tight, there's no going back, you need a fresh gasket, and a torque wrench.
Old Dec 30, 2010 | 09:27 PM
miller502's Avatar
alright , now heres my question with that what if the bolts are backing out ?.
Old Dec 30, 2010 | 09:30 PM
00PhillySi's Avatar
If bolts are backing out then you stripped the threads out, you need to rethread those holes with either an oversized thread tap or helicoil insert.
The most likely cause of them backing out is because you put them in too tight to begin with and stripped out the soft aluminum threads in the block.
Old Dec 30, 2010 | 09:34 PM
miller502's Avatar
ah see. all right i guess i'll look and see what i can find out with it , thanks for your help .
TahitianEG
Jan 11, 2007 10:22 AM
LAKER HATER
May 21, 2004 07:51 AM
Chris93Si
Sep 1, 2003 08:37 AM
NateTEG95
Aug 29, 2003 12:38 PM
