where to buy Sway bar hardware
I pulled an ASR rear Sway bar out of a wrecked EK but it doesnt have any of the hardware such as bolts, links, bushings etc to install it. Any site that has everything I need to install the bar?
not sure if you can get it direct, but have you checked with ASR directly to see if you can get the required hardware from them?
You didn't specify whether you got the bent bar or straight bar...I'm assuming the straight bar.
Don't know if you can individually purchase the parts from ASR or someplace like JHPUSA.
Here are a couple of links to their sites though.
http://www.asrparts.com/
http://www.jhpusa.com/store/pc/viewP...ry=357#details
FWIW...all ASR bars are Speedway Engineering pieces (the straight NASCAR style bar). You can order the bushings and arms from them and have them bent and drilled for your application, as well as order different center sections.
http://www.1speedway.com/Swaybar_Arms.htm
http://www.1speedway.com/Swaybars.htm
Hopefully you have a picture of an EK with the bar in place so you can see exactly what you need.
fracas
Oct 19, 2006 07:11 PM
