Pulling the alternator on a del sol
Old Dec 30, 2010 | 09:35 AM
Rikature's Avatar
Default Pulling the alternator on a del sol
Hey, so I'm pulling my alternator on my 93 del sol. It's a z6. I got the top bolts and the bracket off, pulled off the belt. I took the nut off the bottom pivot bolt, but I can't get that bolt out for the life of me. I've tried spraying some pb blaster on it and everything. Theres no room to get a hammer in there or anything. Didn't know if anyone had experience with this or not. Just looking for ideas.
Old Dec 30, 2010 | 09:50 AM
4dregDC's Avatar
Default Re: Pulling the alternator on a del sol
Try moving the alt. back n forth this should loosen up da bolt a bit, get under the car n see if u can fit a flat head screw driver
Old Dec 30, 2010 | 09:54 AM
ek4_b16a's Avatar
it's rusted in there. i had a 93 civic lx and had the same issue. i bought the car with a bad alternator that just needed to be swapped out. i tried what 4dredDC stated; didn't budge. so, i decided to cut the bolt out from various angles. couldn't get a hammer in there at all. if you don't want to cut the bracket or bolt like i did, then your best bet would be to drop the motor and try hammering away with the engine out of the bay. i cut both bolt and bracket off. i was lucky to have another bracket and bolt laying in my garage. but to the OP, GL!
Ntxhuav
Old Dec 30, 2010 | 09:55 AM
Rikature's Avatar
I'll try 4dregdc's idea, but unfortunately it's not in a garage or anything. It's in my driveway and I have no engine lift or anything.
Old Dec 30, 2010 | 09:56 AM
ek4_b16a's Avatar
see if you can hammer the bolt from the other side just to try n break up the rust or whatever is in there holding it...
Old Dec 30, 2010 | 10:01 AM
4dregDC's Avatar
Wd40 would also help loosen up sum rust
Old Dec 30, 2010 | 10:18 AM
Rikature's Avatar
Used almost a whole can of pb blaster. Hammered on both sides of the bolt. Moved the alternator back and forth a hundred times. Still won't come out. I took one bolt out of the lower bracket thinking that I could take the whole bracket out. The second bolt is in a really tight spot and i can't even get it with a wrench. If I could get that bolt out, then I could get the pivot bolt out from outside of the engine bay which would solve all my problems. Any ideas?
Old Dec 30, 2010 | 10:25 AM
spdzne4dr's Avatar
impact with extensions, have you tried breaker bars??
Old Dec 30, 2010 | 10:27 AM
kaiba's Avatar
Worst comes to worst. Remove the engine to remove alternator.
LOL
Old Dec 30, 2010 | 10:28 AM
ek4_b16a's Avatar
just cut it out...
Old Dec 30, 2010 | 10:32 AM
kaiba's Avatar
Forget the alternator. Just run dozens of batteries.
Old Dec 30, 2010 | 10:34 AM
Rikature's Avatar
Okay so what's the best way to cut it out? And can I just go to the local Honda dealer to get a new bolt after?
Old Dec 30, 2010 | 10:43 AM
Rikature's Avatar
Already got the nut off the end of the pivot bolt, just need to get the bolt out of the bracket and alternator on the bottom.
Old Dec 30, 2010 | 12:36 PM
94EG8's Avatar
Seagull Management
You can usually drive them through with a hammer and punch, you'll have to remove the driver's side wheel first.
Old Dec 30, 2010 | 02:14 PM
ChokolAwt's Avatar
turn the wheel to the right, get a flathead screwdriver in the bolt head end and pry back and forth.
Old Dec 30, 2010 | 03:52 PM
Dontoh's Avatar
long *** prybar and breaker bar?
Old Oct 19, 2012 | 07:05 AM
splashy's Avatar
I have this same problem, any new suggestions to get that bolt out?
Huhuarf
Aug 30, 2018 11:24 AM
PUNJABEE
Honda Civic (2001 - 2005)
Jun 15, 2014 05:48 PM
Phshorty
Dec 10, 2007 04:48 AM
roadhead
Jul 18, 2006 08:27 PM
GroundZer0 336
16
Mar 4, 2004 07:30 AM
