Blue smoke after OEM catback install on 99 Si
Old Dec 30, 2010 | 07:52 AM
05foresterxt's Avatar
Default Blue smoke after OEM catback install on 99 Si
Last night I took off the cheap/rattling muffler shop catback that my 99 Si had and install an OEM one that I bought on Craigslist. This morning on my way to work I noticed blue smoke coming out from the exhaust. This is the first time I've seen this and it has never done this before. No other issues on the car, but an oil leak that I think might be coming from the rear main seal.
Could the oem exhaust somehow be causing this or did something go wrong all of a sudden?
Old Dec 30, 2010 | 07:56 AM
EJeff8's Avatar
Default Re: Blue smoke after OEM catback install on 99 Si
Probably have better pressure, causing you to now run rich?
Old Dec 30, 2010 | 08:00 AM
Hmmmm...weird, I'm hoping it's not something serious because it was not doing this with the crappy exhaust.
Old Dec 30, 2010 | 08:21 AM
JasonYo's Avatar
Reset your ECU.
If running rich is the problem then the ECU should sort it out since it's a oem exhaust.
Old Dec 30, 2010 | 08:37 AM
apexi_rsx's Avatar
blue smoke means its rich i thought that was black smoke? hes burning oil or old oil that is burning out from the exhaust from the previous owner.
Old Dec 30, 2010 | 08:42 AM
EJeff8's Avatar
White smoke is lean, blue smoke is rich, no? Also, the "old oil in the new exhaust" idea sounds plausible.
EJeff8's Avatar
Old Dec 30, 2010 | 09:04 AM
grumblemarc's Avatar
The Grumpiest
White/Blue=oil. Black=fuel.
Old Dec 30, 2010 | 09:46 AM
Took the car for another drive and there is no more smoke. I think that the previous owner had oil in there or from all the sprays that it was soaked with. I am starting to smell burned oil though, but I know it's from that leak that it has. It has the be the main seal, at least I think, because it's coming right from the area where the transmission meets the engine. I've replaced the oil pan gasket and the evap little canister seal, but oil is still coming out from that area.
Old Dec 30, 2010 | 10:42 AM
EJeff8's Avatar
A new thread devoted to that problem would reveal the best results.
drave
Oct 15, 2008 09:31 AM
HamiltonRex
Sep 14, 2006 08:34 PM
marwin
May 7, 2005 07:02 PM
VTC_CiViC
Nov 3, 2003 01:14 PM
Flux
Mar 31, 2002 08:41 AM
