CR-Z makes Motor Trend Top Ten Worst Handling list
http://jalopnik.com/5721280/the-ten-...g-cars-of-2010
"Sadly, there's an end of the skidpad scale we tend to ignore (wait, cars go below 1.0g?!) — clumsy, oafish and over-sized cars that handle like stuck pigs. Luckily, Motor Trend tests 'em! Here's the ten worst-handling cars of 2010.
10. 2011 Honda CR-Z EX CVT/2010 Toyota 4Runner Trail (tie)
Figure Eight: 29.0 sec @ 0.57 g (avg)
Skidpad: 0.78/0.73 g (avg)
9. 2011 Honda Odyssey Touring Elite/2011 Lincoln MKZ Hybrid/2010 Volkswagen Routan SEL (tie)
Figure Eight: 29.0 sec @ 0.56 g (avg)
Skidpad: 0.73/0.79/0.73 g (avg)
8. 2011 Chrysler Town & Country
Figure Eight: 29.0 sec @ 0.54 g (avg)
Skidpad: 0.73 g (avg)
7. 2011 Hyundai Sonata Hybrid
Figure Eight: 29.1 sec @ 0.55 g (avg)
Skidpad: 0.75 g (avg)
6. 2011 Hyundai Santa Fe GLS
Figure Eight: 29.2 sec @ 0.54 g (avg)
Skidpad: 0.77 g (avg)
5. 2011 Honda Odyssey EX-L
Figure Eight: 29.4 sec @ 0.56 g (avg)
4. 2010 Mercedes-Benz GL 450
Figure Eight: 29.6 sec @ 0.54 g (avg)
Skidpad: 0.70 g (avg)
3. 2010 Toyota Yaris
Figure Eight: 29.6 sec @ 0.53 g (avg)
Skidpad: 0.76 g (avg)
2. 2010 Honda Element EX
Figure Eight: 29.8 sec @ 0.52 g (avg)
1. 2010 Dodge Grand Caravan SXT
Figure Eight: 30.5 sec @ 0.52 g (avg)
Skidpad: 0.67 g (avg)"
Its probably just the tires. A hybrid comes with rock solid low rolling resistant tires with the sole purpose of getting good milage. I bet if you put civic si tires on it, it would be way better.
If it was the HF, it'd still have nimble handling, it wouldn't weigh 2600lbs, it wouldn't cost $22K, and it would be getting FAR BETTER fuel economy! This car is a joke every which way and it's really a testament to how underwhelming Honda's product line has been in the last decade.
the ****?
If it was the HF, it'd still have nimble handling, it wouldn't weigh 2600lbs, it wouldn't cost $22K, and it would be getting FAR BETTER fuel economy! This car is a joke every which way and it's really a testament to how underwhelming Honda's product line has been in the last decade.You see since the HF there has been this wonderful thing called "safety" A rolling rattletrap car is far from the safety standards that are used today. You cannot just add safety features (read, ABS, airbags, crush zones, etc) without adding weight.
You also seem to have ignored the point someone made above where it was most likely due to the stiffer tires on the car, I'd personally be interested to see where a Prius and Insight score in comparison. They both might be tied at .79 and right behind the CRZ.
I will agree the fuel economy for a hybrid like the CRZ is poor, when a Fit can practically outdo it with more space.
Tell me how you really feel.
I think YOU'RE missing the point that this car is a piece of **** excuse for a sporty hybrid. It's crap in every segment and appeals to noone except a damned fool. Why would I buy this car if a Prius gets better mileage, can be had for the same money, much larger, has similar performance (wtf?), etc???
Yes you can, See Honda Insight from 2000-2006... None of those things would account for the weight increase from 1800lbs to 2600lbs. Crush zones have been in cars since the 70s and that's the only thing that would *Potentially* add weight to the car substantially. All those things you listed would only drive up the price of the car, not add substantially to the weight. But even then, if you compare this car to the Ford Fiesta, the Fiesta wins across the board when you consider it isn't even a hybrid and because of that is significantly less money unless you start tacking on the amenities.
The Insight has a 1.0L 3cyl engine vs the CRZ's 1.5L 4cyl. You also have the earlier generation of the IMA system which is NOT identical to the new system so weights are going to differ. Without knowing 100% I do know most other Hondas went from the double-wishbone to the MacPherson strut system which has added weight as well. Knowing that is applicable to Civics, I'm going to wager the Insight (1st gen) used double-wishbone and the CRZ uses the MacPherson. My point of stating those items was they have been improved since they were introduced, if you are saying they are identical to what they were in the 70's you are kidding yourself.
I'm also going to say in crash tests I have an inkling the CRZ will outperform the Insight.
Unfortunately, I agree that the CR-Z is a poorly executed car. Good mileage? Not really. Good handling? Not really. Somewhat quick? Not really. When you have a car that can't do ONE thing well, it pretty much sucks. Honda needs to pull their head out of their rear and make this car something to brag about by someone. Gas mileage people giggle at it for getting regular gas mileage (or worse) while being a hybrid. Handling people laugh, well, because it's on a list of the top ten worst handling cars. Performance people laugh because they suck at acceleration. They did decent on the looks but I think the car is still a bit chunky, both in looks and weight.
Put a K with a 6 speed in it and call it an Si, put a REAL hybrid drivetrain in it that gets REAL hybrid mileage and call it an H something (HX, HF, etc). Or just call the turd they currently sell the Base or Standard since it pretty much sucks....
1960 lbs to 2725 lbs (curb weight CVT models)
And I never said it was an awesome car, but it is apparent they are not targeting you as their audience. I wouldn't buy one either for similar reasons. I think it is too expensive and I would rather have a Fit or Fiesta as well. But when you argument is "**** this car and **** Honda" you really do not come off as a reasonable source.
at least the fit isn't on that list.. although, there are a lot of hondas...
Uhh, no. It doesn't. 35/39 for CVT and 31/37 for 6 speed. In comparison, a 2011 Civic hybrid is rated at 40/43 (still not great), the Insight is rated at 40/43. Pretty sure the Civic and Insight are both heavier but still get quite a bit better gas mileage.
my wife's 08 fit sport manual can get 31/37.. AND seats 5.. AND isn't on this list.. but it is no "sports hybrid". hahahaa.
In what world does the skidpan lateral G from grip relate to the actual handling of a car?
Also im not sure double wishbone is actually lighter than McPherson. I know lighter than double is what Ford champion with their RevoKnuckle.
Im amazed that so far in the Insight discussion it hasn't yet been mentioned that the Insight is an tiny bodied aluminium monocoque, hence its so light and the engine is a frankley comical 124lbs, with little ally wheels and uber light and low rolling resistance tyres (Re92 - 13lbs), it even has ally drums.
You can not really use it as a benchmark for anything Honda can make that will actually make them money.
This makes no sense? What are the rules for this test? Why is a 2 door hatchback being compared to minivans? So a Hummer handles better? This is ridiculous.
all this High MPG stuff these days is a joke.
