Gauge Cluster problems, need help please.
Old Dec 30, 2010 | 12:32 AM
White Boy Hatch's Avatar
Icon6 Gauge Cluster problems, need help please.
I have a 92 Hatchback, stock engine, non Vtec. Stock car haha
My gauge cluster is a little wack, or the wiring in my dash is, from some owner before.
The problem: First off, NO CHECK ENGINE LIGHT, Speedo doesnt work, just sometimes like on its own or when i smack the dash, also, at night the lights dont light up all the time, same problem, they work when they want. With the lights it also is with the climate control lights. Tacho works fine and so does my miles gauge. Gas gauge is iffy, saying it doesnt stay where it is, goes up and down. but it gives a good enough estimate haha.
I took out my cluster to check connections and everything looked fine. Please help me.
Old Dec 30, 2010 | 07:42 AM
Former User's Avatar
Default Re: Gauge Cluster problems, need help please.
Speedo:
Does the CEL work?
Cluster/climate control lights:
Pry the dimmer switch out of the dash, unplug the connector, and then use a short piece of wire to jump/short the red wire to the black wire in the connector. Do the dash lights now work?
Old Dec 30, 2010 | 09:25 AM
Havnt tried CEL.
Where is the dimmer switch in the dash?
Im new at the car tech stuff haha
Old Dec 30, 2010 | 02:20 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by White Boy Hatch
Havnt tried CEL.
On the dash.
Old Dec 30, 2010 | 03:56 PM
Like the headlight switch?
Old Dec 30, 2010 | 08:19 PM
wheelmanbg's Avatar
It's on the left side of the dash, NOT on the steering column. It adjust the brightness of your dash lights.
As far as speedometer, change your cluster. I've been through 3 clusters because the speedometers stopped working properly.
Old Dec 30, 2010 | 09:38 PM
oh ya, I dont have one of those, there is just a hole there
Old Dec 31, 2010 | 02:01 PM
any other suggestions?
Old Dec 31, 2010 | 02:04 PM
The Grumpiest
There should still be a connector for it under the dash. Locate it.
Old Jan 2, 2011 | 10:52 AM
so i jump the two wires with another wire with the key ON correct?
Old Jan 2, 2011 | 11:02 AM
ricky00's Avatar
could just be ur circuit board on the speedo thats bad.. i had a bad speedo so i took off a good working circuit board n attach to my speedo and it started to work fine again.. i couldve switch the whole cluster but i wanted my original mileage on my car..same goes for my rpm too.. my old stops at around 5-6k switch the circuit board n goes to 9 accoring to my chip ecu
Old Jan 2, 2011 | 11:08 AM
The key can be in the OFF position. You just need to turn the light switch on (parking lights are sufficient).
Old Jan 2, 2011 | 11:09 AM
where would I get the circut board
Old Jan 2, 2011 | 11:18 AM
ricky00's Avatar
u can find it on any cluster u just have to pop it open.. but make sure its a full working one.. try to find a bad cluster (rpm not working) and use the speedo from there
Old Jan 2, 2011 | 11:25 AM
Given that the climate control lights also don't work (see first post), a bad cluster circuit board seems quite unlikely.
Old Jan 2, 2011 | 01:51 PM
ok so there are two red and one black, just any red one?
Old Jan 2, 2011 | 04:17 PM
Actually, one is Red, and one is Red/Blk. Jump the red wire to the black wire.
DannyGo
Oct 7, 2014 08:15 PM
B_Swapped93
Jul 17, 2013 05:16 PM
Teggyb18a
Sep 26, 2010 11:30 AM
92'si
Nov 12, 2005 09:07 AM
veganej
Aug 26, 2004 06:52 PM
