EG Seibon Carbon Fiber Hood Fitment
Old Dec 29, 2010 | 06:00 PM
Zaraki's Avatar
Default EG Seibon Carbon Fiber Hood Fitment
I'm having some issues with the fitment of my hood.
There's a little gap in the front where it closes and it seems lower on the left side than the right.
How do I adjust this?
Old Dec 29, 2010 | 06:10 PM
habib's Avatar
Default Re: EG Seibon Carbon Fiber Hood Fitment
Carbon fiber will not fit perfectly like oem, it will be off. How bad is the gap
Old Dec 29, 2010 | 10:33 PM
ej1916's Avatar
^ He's right. I got Carbon fiber fenders on my car and the fitment is ****. Best thing to do is to get it to fit as good as possible and leave it be. As long as it doesn't fly off when your driving then don't worry to much about it.
Old Dec 30, 2010 | 05:21 AM
apexi_rsx's Avatar
glad my seibon oem hood fit like butter on my ek... must be hit or miss. if its not marked seibon then its not a seibon and someone tried to sell it as one. i know some of these poorly made carbon products will not fit rite. you have the rubber stoppers on the front rad support you can adjust these by turning them in and out. u will need to set these so ur hood will have tension it so it will pop when u hit the latch in the car. this could solve why one sides sitting higher in the front then the other. goodluck
Old Dec 30, 2010 | 05:25 AM
Libertariat's Avatar
Ek Forever y0!
Indeed. There are several rubber stoppers you can adjust to try to make ti fit better. Try that and see how it works.
Old Dec 30, 2010 | 09:34 AM
vtechjunkie's Avatar
It is rare that you get a large manufacturer hood that will fit well. They have them made by highly un-qualified personel, and the rarely re-make the molds to ensure the parts aren't warping in the mold. Furthermore, they pop the parts out so fast that most of the cure process is done with the parts out of the molds. You just have to adjust it till it fits as well as it can. GL
Old Dec 30, 2010 | 10:52 AM
Zaraki's Avatar
It's a real Seibon hood.
The fitment isn't terrible, but it's not perfect. I did try adjusting some of the rubber, and that seemed to help.
It just doesn't fit like OEM.
Old Dec 30, 2010 | 08:04 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Nothing will.
Old Dec 30, 2010 | 09:41 PM
00PhillySi's Avatar
Best thing for adjusting hoods is using washers on the bolts that hold the hood to the hinges, this way you can sort of fine tune your fitment one washer at a time until you get the fitment you want.
The same applies for fenders, trunks, etc. Use washers and you can make anything fit like OEM. (As long as its not complete **** to begin with.)
Old Dec 31, 2010 | 01:20 PM
Zaraki's Avatar
Any more info on that?
Old Dec 31, 2010 | 01:29 PM
At Composites Fab we made hoods that fit like OEM. LITERALLY. It all comes down to making the molds correctly. If the molds are made with care, they will make quality parts. If your hood doesn't fit, then you may want to look for a new hood. You can also adjust the hell out of every panel your car to make it look better.
mish__
Paint and Body
Jan 23, 2017 05:33 PM
boostedefhatch
10
Mar 31, 2009 09:32 PM
torqueless
Apr 30, 2005 03:15 PM
:jdmshmaydm:
Dec 13, 2002 01:55 AM
