Timing belt very loose
Old Dec 29, 2010 | 03:45 PM
95turbotypeR's Avatar
Default Timing belt very loose
B18c5 gsr head. Car was idling, no miles on motor yet, heard horrible rattling noise, belt hitting plastic cover, turned car off as quickly as possible. Not metal noise that I heard.
So what should I do, re tighten belt and see if car runs, or pull head off and check everything?
12.5:1 comp. Built head bc valves,springs etc sk2p1 cams
Old Dec 29, 2010 | 04:57 PM
sublime423's Avatar
Default Re: Timing belt very loose
I would check belt tension first. I wouldn't run the engine again until you find the problem.
Old Dec 29, 2010 | 10:04 PM
mouab18c1's Avatar
Align your timing back to TDC to see if it jumped time. Then I would re tighten your timing belt again.
Old Dec 29, 2010 | 11:38 PM
racebum's Avatar
did you cycle the engine multiple times by hand counterclockwise when you installed the timing belt? if you didn't and tightened the tensioner before hand this is what caused your problem
Old Dec 30, 2010 | 02:41 AM
Well my cousin actually set the timing b4 I got there he's done many many b4 so I'm cannot exactly say what he did. I did just order the gates belt. The tensioner moved, but is not loose. I do not know exactly how much compression the motor has, however I do know turning the motor over by hand seemed to "wrinkle" the timing belt. Car was run quite a few times just sitting in the garage. Very confused will reset timing w new belt and see what happens!!!!!
Old Dec 30, 2010 | 03:04 AM
racebum's Avatar
this post doesn't even make sense
ignition timing has ZERO to do with setting the belt up right
the belt also does not wrinkle when you spin the motor counter clockwise, it does when you spin it clockwise.
read the timing belt DIY on here and follow it to the T
this engine is going to wind up with a valve in a piston at the rate you're going
Old Dec 30, 2010 | 03:24 AM
Sorry was referring to "setting the timing" as puttimg the "timing belt" on. My bad and yes that was turning it clockwise. Thanks again
Old Dec 30, 2010 | 06:13 PM
mouab18c1's Avatar
These motors are only meant to be turned counter clockwise.
Old Dec 31, 2010 | 05:33 PM
Cynical 1's Avatar
yeah, that is your problem if you are turning it clockwise... no way to get the belt tensioned at all, and it likely has jumped some teeth...
Old Dec 31, 2010 | 07:38 PM
well its running again.appears as if the tensioner came loose. Bought a gates belt, a new tensioner bolt, and reset the timing, and torqued the tensioner bolt. hope everything is ok now. thanks everyone!!!
Old Jan 1, 2011 | 07:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
make sure the washer that goes behing the crank pulley is there if not the belt will move and rub the plastic cover and inner valve cover!
timothywhitt
Apr 26, 2012 04:24 PM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
bfeils
Mar 24, 2007 10:20 AM
jsnm
Aug 29, 2005 09:44 AM
precord96
Mar 4, 2005 05:51 PM
