Classic Hondas All Pre-1988 Hondas.
1982 civic 1300 gauge cluster
Old Dec 29, 2010 | 12:49 PM
antihero12's Avatar
Default 1982 civic 1300 gauge cluster
ok so i own a 1982 honda civic 1300 non cvcc 4 speed. and the gauge cluster doesnt have an rpm gauge. was there any model like my civic that has the gauge cluster with the rpm gauge? cause i wanted to do a gauge cluster swap. but one of thing is how would i wire up the rpm part? any help would be great
thanks
Old Dec 29, 2010 | 01:23 PM
spoolin94ls's Avatar
Default Re: 1982 civic 1300 gauge cluster
if u buy a aftermarket tach u can wire it off the dizzy
Old Dec 30, 2010 | 03:33 PM
antihero12's Avatar
ok sorry but what is the dizzy??? and where would u recommend getting the aftermarket one
Old Dec 31, 2010 | 06:18 PM
smithenhiven's Avatar
11:11
You could get a cluster out of a second gen Civic 1500S, or 1300FE (there may be more cars with tachs, but those I do know have tachs). The tach in these clusters are cable driven, so in addition to the cluster itself, you'll need the tach cable. Before you do that, make sure your transmission has tach cable output (I would assume it does, and is just plugged/capped, but it wouldn't hurt to check first).
I've got a spare cluster out of a 1300FE with tach, but I don't have a spare tach cable.
Old Jan 1, 2011 | 05:50 PM
Cobourg Classic's Avatar
The tachometer is driven off the end of the camshaft on the 2nd gen Civic. You will also need to source the tach drive end off of a 1500S or 1300FE, it is different than the standard empty casting on the end of the head.
Old Jan 2, 2011 | 01:35 PM
antihero12's Avatar
ok cool thanks i will check that out. but do you know where i should check for that plug? and r u willing to sell me that gauge cluster of yours? if so how much do u want for it? thanks
Old Jan 4, 2011 | 05:32 PM
Stretch7's Avatar
Also the Civic S model has the tach in the cluster.
Old Feb 15, 2013 | 06:54 PM
damageinc86's Avatar
does anyone know if there are any other early to mid-80s hondas that share that tach cable? I'm in desperate need of the cable. Found a 1500S in a junkyard but some dolt undid that cable from the coupler portion, so all I have is a hollow tach cable.
Old Feb 17, 2013 | 07:37 PM
NW Classic Honda's Avatar
There is a 2g at my local yard with the tach and cable. Ill go add it to my collection in the morning.
raverx3m
Nov 10, 2013 08:18 AM
JDMJUNKIEMONKIE
Oct 22, 2009 10:36 AM
949
Sep 7, 2007 04:45 AM
DWHONDA
Jun 2, 2006 06:06 PM
Civic89
Jul 18, 2002 10:34 AM
