Eg hatch with EG EX body/car harness!, need some help.
Old Dec 29, 2010 | 09:53 AM
civic-8442-'s Avatar
Default Eg hatch with EG EX body/car harness!, need some help.
ok so i have a eg hatch 92' and i had a 95 civic ex coupe as a donor car wrecked . so i stripped dows he coupe and swapped everything over to my hatch power windows etc... i used all EX coupe harness for the hatch it was all plug and play but now my problem is the second part of the harness in the car that splits by the rear drivers side quarter panel (main plug) for the taillight harness is completely different than the hatch original one. so ive tried to just plug in the stock hatch tailight harness to the ex front harness in the hatch and i blow fuses i looked up wiring diagram its ways different, so then i tried using the eg coupe harness for tailights and all the plugs are diff. so all in all i need wiring diagrams for the tailight seperate harness for both EG coupe ex and eg hatch vx.
has anyone done this before? if so what did you do for the tailights/harness to amke it work? sorry if all this sounds confusing..
Old Dec 29, 2010 | 09:57 AM
94EG8's Avatar
Seagull Management
Default Re: Eg hatch with EG EX body/car harness!, need some help.
If i'm reading this right the hatch rear section plugs in but blows fuses? Repin it so it doesn't Either check the wiring diagrams or compare what each pin does to the EX rear harness, repin accordingly.
Old Dec 29, 2010 | 10:01 AM
90_EX_Civic's Avatar
is there a reason why you wanted to do this swap?
Old Dec 29, 2010 | 10:09 AM
yeah thats what im thinking but i need to find a wiring diagram for the rear section plugs of the harnesses. anyone have the wiring diagrams?
Old Dec 29, 2010 | 10:16 AM
something to do lol minus well do it since i scrapped the coupe.
Old Dec 29, 2010 | 10:19 AM
thissucksturtle's Avatar
i have this same setup in may car no fuse's are blown , i had to run one new wire for the brake lights thats it
Old Dec 29, 2010 | 10:22 AM
it's just to say that if you did it so that you would have the vtec wiring harness, you didn't have to do the swap. 92 civics had the harness from factory to run vtec.
if it was so you would have power window and locks, okay.
Old Dec 29, 2010 | 10:42 AM
i know about pre wired for vtec on 92, i did it for the power windows etc..
Old Dec 29, 2010 | 10:48 AM
can you give me more info? the hatch harness literally has like 3-4 plugs for taillghts etc and the coupe has a **** load and plugs are diifferent which haness did u use? etc..
Old Dec 29, 2010 | 10:51 AM
, will good luck to you then sir.
Old Dec 29, 2010 | 10:53 AM
anyone have a link to wiring diagrams??????? or know where i can find it online?
Old Dec 29, 2010 | 11:15 AM
i used a civic ex front floor harness and the original rear civic hatch wiring
Old Dec 29, 2010 | 11:56 AM
yeah thats what im using, literally every harness/wire in the car is from a civic ex, and i plug in the hatch rear part harness for taillights etc and it blows my taillight fuse
Old Dec 29, 2010 | 02:57 PM
bump!
Old Dec 29, 2010 | 02:59 PM
check for the ground on the rear harness its on the car in the rear under the tailgate
Old Dec 29, 2010 | 07:12 PM
crxalx's Avatar
Old Dec 30, 2010 | 09:16 AM
what are you talking about?
Old Dec 30, 2010 | 12:08 PM
there is a ground wire for the rear section of the harness it gets bolted to the car with 10mm bolt were the spare tire goes
Old Dec 30, 2010 | 12:27 PM
yeah i know. thats not my issue. lol thanks though
Old Dec 30, 2010 | 04:04 PM
94EG8's Avatar
Seagull Management
Just gone done looking through the ETM (I only have a hardcopy so no PDF hookup) its connector C590, but there's no pinout. Take a look at both plugs, check it pin by pin against each other, see what's different, repin.
Old Dec 30, 2010 | 07:51 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Yes, do what 94EG8 says. Match up the wire colours - they will all be the same ... oh, except GRN - there's a GRN for the trunk-open indicator and one for ummmm... something else - might be rear wiper. Not a problem though if you don't have a rear wiper.
Old Aug 24, 2011 | 07:14 AM
pink94coupe's Avatar
sorry to bring up an old thread but im having similar problems and i was curious what wire you ran because its only my brake lights that are not working..thanks
Jodiibuilt
Aug 2, 2018 07:02 PM
OlHatch_
Dec 16, 2013 10:42 AM
Hyunbs
Apr 8, 2013 11:01 AM
johndoe67
Apr 12, 2012 05:32 PM
96cypresgreenls
Jan 10, 2012 09:09 PM
