Is this a 98+ or a pre-98 JDM ITR?
Guys,
I just picked up a full swap from a JDM ITR:
Video:
http://www.youtube.com/watch?v=Nd2bLEgRYh0
How can I tell whether or not the car was a 98+ or a pre-98?
If it helps at all, the steering wheel was MOMO without airbag.
Thanks for your help,
-Walter
Video:
-Walter
on the head, right above the header/exhaust manifold, ther are some numbers stamped and they tell you the year that the motor was made. usually the numbers are just two(2) numbers with a line between them and they have a circle around the both numbers.
Indeed Sir. I wonder whether it's the looks of it or the "sounds" that revealed this to you.
I am a bit disappointed it's a pre-98. I was hoping it was a 98+. Now I need to find out the exact differences between the two years. Oh well.
Thanks again for the help guys.
-Walter
Correct. I've been reading up on this and learnt that pre-98 airbags were optional while 98+ were standard.
-Walter
-Walter
-Walter
-Walter
http://pistonheads.com/sales/2353031.htm
for all comparisons, look no further than
http://www.integratyper.org/specs/master_comparison.htm
good site, great info.
here is another one
http://pistonheads.com/sales/2337037.htm
and another.
http://pistonheads.com/sales/2110073.htm
and another.
And to the OP: they swapped motors in Japan just like we do, especially if there are engine/emission problems so it is worth checking the headstamp. There is also little to no difference in the 98+ motor except for the methods used to assemble/finish the motor and the CTR cam (virtually unnoticeable), they do however have a different transmission and header.
Ok, well airbags were an option in all years of the DB8 ITR 95-01 and were 100% optional in the 98+ DC2's, you could also get your Rx without a supplemental restraint system.. they were much more common in DB8R's than in DC2R's from what I have seen. The DB8's also came equipped with a much different drivers wheel than the DC models when equipped with SRS (looks much like our steering wheels except with H emblem).
This guy?
