Honda CR-V & Element 2WD & 4WD Element & CR-V
01 crv stalls when cold
Old Dec 29, 2010 | 05:45 AM
jpcm22's Avatar
Default 01 crv stalls when cold
Ive got a 2001 crv that initially starts and idles fine when cold in driveway,as soon as i try to drive it,it will stall and hard starting after that.When i do get it running after letting it sit for a few minutes and then let it run for about 15 minutes and let it warm up it will run fine after that. Very hard to diagnose it only acts this way on initial startup. anyone have any ideas, its had a tune up new plugs cap rotor ign wires. thanks jp
Old Dec 30, 2010 | 12:01 PM
jpcm22's Avatar
Default Re: 01 crv stalls when cold
Anyone have any thoughts on what might be wrong Thanks jp
Old Dec 30, 2010 | 12:29 PM
Targa250R's Avatar
be professional
Have you checked the valve lash lately?
Is the Check Engine light on?
Old Dec 30, 2010 | 01:47 PM
fast2camciv's Avatar
when it stalls....dont touch anything. reach over and turn on the headlights. do they come on?
Old Dec 31, 2010 | 06:48 AM
jpcm22's Avatar
Hello No i havent checked valve lash but will be first on my list and the headlight trick, just purchased this vehicle ,not to familiar with it. Thanks for your info,I will keep you informed. Thanks JP
Old Dec 31, 2010 | 10:48 AM
AP14TW's Avatar
Is the headlight thing a joke? I would imagine so. I am thinking main relay or maybe fuel filter? anyone think that sounds about right. I would go fuel filter first, cheap and usually neglected. BTW. my S2000 does that but it starts right back up. Trying keeping it running with your foot on the throttle.....
Old Dec 31, 2010 | 12:54 PM
MonkeyMagic's Avatar
how cold are we talking? like where do you live op?
no cel right? and is it an automatic?
Old Dec 31, 2010 | 02:43 PM
chupaCRO's Avatar
Mate, try first to Valve Adjustment, because i have same problem on my 99AT B20B3, after i fiks valve, problem is missing
Old Jan 1, 2011 | 11:37 AM
jpcm22's Avatar
Thanks for your info, Checked the valve lash this morning and found exhaust valves on number 1 and 3. cylinders very tight actually held open about ten thous.Reset valves to proper clearance and that took care of the stalling problem instantly. Did compression test because missing on one cylinder, number 1 cyl 50 psi 2-175 psi 3- 145 psi 4- 175, Guess the head has to come off. Thanks again for all your help JP Happy New Year.
Old Jan 1, 2011 | 01:52 PM
no..its an easy way to help diagnose a bad ignition switch....which has been recalled on a CRV. random stalling is a good idicator of a a bad ignition switch.
glad to hear you tracked down the issue! sorry to hear about the valve damage
Old Jan 1, 2011 | 01:58 PM
Targa250R's Avatar
be professional
The headlamp circuit is hot at all times. The parking lamps and headlamps will work whether the ignition switch is on or off.
Old Jan 5, 2011 | 09:36 PM
AP14TW's Avatar
haha, well that's random. Thanks for the info!
Old Feb 23, 2011 | 03:10 PM
MeatCheezy's Avatar
Hmm...had the same problem, valve lash took care of it. Now we have bigger issues. Dealer told me to check the valve lash, replace distributor cap, rotor, timing belt, all belts, water pump, and plugs (major tune up). I have installed everything, but am having trouble with the timing. I checked the TDC 3 times, all is well. Haven't checked the timing, to see if I fouled up the timing when I took the distributor off to replace the rotor. Still runs rough. Being a trial user on Honda Tech, I can't post anything. I can do the work if I would take the time to read all of the help I have received from searching and Haynes (not a good manual for the '01 CR-V), because it doesn't have anything specific to the DOHC and timing belt. Between busting bolts (due to over-torquing the bolts due to conversion from in-lbs to ft-lbs, I'm an idiot), stripping off bolt heads, and not having enough power for removing the pulley bolt, I think I'm holding up well!!!
t0mmyt
Jun 6, 2013 10:16 AM
PhilMac23
Honda Civic (2001 - 2005)
Nov 5, 2012 11:30 AM
cpeterman07
Dec 4, 2011 05:54 AM
SOHCMAN
Nov 3, 2007 05:42 AM
mr3sgte
May 15, 2007 06:19 PM
