The [U]BRAKE[/U] light keeps coming on and off.
Old Dec 28, 2010 | 10:47 AM
Live~Civic's Avatar
Icon2 The [U]BRAKE[/U] light keeps coming on and off.
My 91’civic runs like a champ, but for some reason the BRAKE light keeps coming on and off. It seems to come on more when the tires spin as if it was a traction control, but also randomly some times. I have had the civic for a year now and this only started two weeks ago. Let me know what you think.
Old Dec 28, 2010 | 10:54 AM
Run Away's Avatar
Default Re: The [U]BRAKE[/U] light keeps coming on and off.
Your brake fluid is probably around the MIN line, check it and see. If it's low, check your
brake pads, they may be worn out, causing the fluid level to go down.
When you replace the pads and push the pistons back into the caliper the fluid level will go back up.
Old Dec 28, 2010 | 11:58 AM
CivicSD's Avatar
low fluid level
Old Dec 28, 2010 | 01:17 PM
Live~Civic's Avatar
Sweet....did not even think about that! Thank you
Old Dec 28, 2010 | 08:16 PM
hatchet_honda's Avatar
the 2 wires goin to the MC cap is what triggers that brake light, and the ebrake of course. first thing you shoulda done was check the fluid level
Old Dec 28, 2010 | 09:13 PM
EL Vap133's Avatar
Do this first!
Do this second!
Old Dec 28, 2010 | 09:18 PM
Tyson's Avatar
how about maintaining your brakes? theyre kinda important.
low fluid means your pads are low or you got a leak. both need attention, but not of equal importance... you can figure it out.
Old Dec 28, 2010 | 09:29 PM
Projekt_Ef9's Avatar
Mine did this too but it wasn't low fluid, or the fluid level sensor, or the brake pads. Mine only did it when cornering hard. It ended up being the circuit going to the e-brake was shorting against the body. If none of there ideas work try that.
Old Dec 28, 2010 | 09:31 PM
Tyson's Avatar
yeah that happens too.
ElCivic89
Mar 16, 2012 01:54 PM
angelscrx
Feb 16, 2007 07:04 PM
Ha7chB4cK
May 3, 2005 06:06 PM
Understeer
Dec 1, 2003 09:40 PM
Proper
Jul 26, 2002 05:57 AM
