F20B full civic ek swap in OHIO
For sale is jdm F20b full swap in 96-00 civic. currently in 99 civic. its the manual engine, which has the type s cams and revvs to 8200, 200hp stock. and i balive 151 lb of tq.has complete obd1 prelude intake manifold and throttle body on it, obd1 one plug dizzy int coil, aft mkt cam seal, oem honda manual tensioner conversion done, and timing belt with all the seals 14k ago. Fidanza 8pound flywheel, exedy oem replacement clutch. tranny is off of 2000 honda prelude. no grinds or nothing, axles from 93 integra gsr, 94 accord half shaft, avid motormounts, accord shift linkage with fidanza short shifter adapter, p13 ecu chipped to vtec at 5000 and rev limiter at 8200. powdercoated red valve cover, h22a obd 1 injectors with resistor pack. all the sensors egr iab all hooked up, using prelude evap canister.hybrid wiring harness made from 94 prelude vtec and 99 civic ex harness, done professionally. every wire was soldered and shrink tubed and taped. looks like oem wiring. has no problems. obd2b to obd1 conversion harness. has been my dayly for little less than a year. asking 2000 firm. pm me. located in central ohio. still in the car.
Wicked Dance
Feb 24, 2005 09:38 PM
