ek with b18c will not start
Old Dec 28, 2010 | 03:47 AM
kulo's Avatar
Default ek with b18c will not start
got the head milled and new headgasket due to engine overheat
tourqed it all down to oem specs
put everything back together
started first time
waited like 20mine
thermostat still aint opened up
checked the engine temp gauge
it was 3/4 hot
so above normal
the head and top radiator hose was getting really hot
so we shut it off
tried to start it again
wouldnt start
just kept cranking
what could it be?
thermostat?
waterpump?
Old Dec 28, 2010 | 04:24 AM
-__-'s Avatar
Default Re: ek with b18c will not start
so ur thermostat is stuck? if where u live has decent weather, just take it out completely.
and it won't start now? sh** hope u didnt blow the headgasket again.
Old Dec 28, 2010 | 04:34 AM
kulo's Avatar
i hope not
it was a pain to change the headgasket
gunna swap out the thermostat later
Old Dec 28, 2010 | 06:20 AM
8YourV8's Avatar
Florida is considered good weather, and hot most of the time, and they had a 30's spell last week and the week before IIRC... swap your thermostat bro, don't take it out.
Old Dec 28, 2010 | 06:28 AM
Former User's Avatar
Don't remove the thermostat. It's needed to control engine temperature in any climate.
Check for spark and fuel. If you have both, compression test the cylinders.
Old Dec 28, 2010 | 06:33 AM
kulo's Avatar
i have no compression tester
gunna remove the thermostat and let coolant go inside the block
since the block and water pump is dry?
Old Dec 28, 2010 | 06:36 AM
You need a new thermostat and to bleed the cooling system, but that's not preventing the engine from starting and running.
Is there bright white spark at all four spark plugs? Does the fuel pump prime? Any CEL codes?
Old Dec 28, 2010 | 06:45 AM
kulo's Avatar
fuel primes
no cel codes
i dont think the spark plugs are the problem?
Click the Check Spark link in my signature.
Old Dec 29, 2010 | 03:26 AM
kulo's Avatar
ok
so it starts straight up
engine temp gauge gets to 1/2 temp which is normal
top rad hose is warm
bottom rad hose it cold
i rev it to 2k rpm
temp gauges shots up to 3/4
what could it be?
ordered new thermostat
so waiting on that
hope the water pump dont need replacing
Old Dec 29, 2010 | 06:47 AM
8YourV8's Avatar
I'd replace it anyway if it's been 75k+ miles. Just to be on the safe side and have the reassurance in knowing that it's brand new. It's not expensive.
h22silvia
Jul 28, 2009 09:53 PM
darkintegra
Apr 28, 2009 12:17 PM
finster
Dec 19, 2008 09:19 AM
dalek
Aug 22, 2008 03:03 AM
Fatty_1775
Jul 17, 2003 11:10 PM
