dpfi to mpfi HELP!!!
Old Dec 27, 2010 | 08:02 PM
omnijdm's Avatar
Default dpfi to mpfi HELP!!!
Sorry if this has already been discussed somewhere else here on ht. I just have a quick question! I have a 89 civic dx with dpfi, I wanted to know if I swap another non-vtec motor into my civic thats mpfi with the wiring harness thats for that motor that im swaping is there anything else that i would need to do for that conversion?
Thanks in advance!!!
Old Dec 27, 2010 | 08:26 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: dpfi to mpfi HELP!!!
Yeah you'd still need to modify your body harness to be MPFI.
Old Dec 27, 2010 | 09:40 PM
tonythetuner®'s Avatar
Yeah you gotta Do some wiring. You gotta add 6 more Wires. well that's how I do it 4 for the injectors from the ecu to the injectors and 2 for the cylinder position sensor.. if your not good with wiring pay some one to do it... or if you fell like you can do it. Hear you go this is the right up I used to learn I have it down pat now I don't even gotta look at it any more lol
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Dec 27, 2010 | 11:49 PM
Clipsed's Avatar
You don't need to add 4 wires for the injectors, only 2.
Old Dec 28, 2010 | 07:08 AM
CivicxTree754's Avatar
Photogenic
Loved
From the OP s question it looks like he'll be using the engine harness that came witht the motor. Is that ok? Someone chime in. I thought ur supposed to use the same harness from the cars original motor.
Old Dec 28, 2010 | 08:34 AM
omnijdm's Avatar
@civicxtree754 that's what I was mainly wondering, thanks for clarifying that for me! Please anyone respond it's much appreciated!
Old Dec 28, 2010 | 08:45 AM
Clipsed's Avatar
You need to use a combination of your original harness with some parts of the swap's harness. If you are unable to do it, give me a holler via pm, I can make the harness for you.
Old Dec 28, 2010 | 08:47 AM
omnijdm's Avatar
Just for further understand I'll give an e.g. If I swap a d16a6 into my hatch WITH the d16a6 wiring harness, do I need to do the wiring?
Thanks again sorry for the confusion!
Old Dec 28, 2010 | 09:05 AM
Clipsed's Avatar
yes you do, any multi point fuel injected engine you will NEED to do wiring.
Old Dec 28, 2010 | 09:23 AM
hmt_whiterice's Avatar
don't forget the ecu
Old Dec 28, 2010 | 10:09 AM
omnijdm's Avatar
Thanks "clipsed" and "hmt whiterice" for the help
Old Dec 28, 2010 | 02:27 PM
blue91EF's Avatar
u need wiring and ecu.
Old Dec 28, 2010 | 02:59 PM
Yes clipsed your right you can run just 2 new wires for the injectors. And splice the other 2 injector clips on to the excisting 2 Fuel injectors from the dpfi harness. But like I said I run 4 for the injectors and make my own subharness with. A 6 pin plug I get from junk yards. So if the motor has to come out I can unplug it from the car. Eaither way works. I just find it easeyer to do it the way I said I guess its up to the person. Doing the wiring
Old Dec 28, 2010 | 03:07 PM
KINGVEM^^ED6's Avatar
clipsed is always rite thats why hes doing my harness
Old Dec 28, 2010 | 03:11 PM
Clipsed's Avatar
Lolz!
Tony I still make my harness to be removable from the car.
Old Dec 28, 2010 | 04:53 PM
John The G's Avatar
can u use the std throttle cable or do i have to get the mpfi throttle cable?
Old Dec 28, 2010 | 05:04 PM
jdm ef8 89's Avatar
Yes the DX throttle cable will work (its a bit long but works fine thats what I use cuz im poor) the Si throttle cable is shorter and looks better.
Old Dec 28, 2010 | 06:17 PM
John The G's Avatar
cool does anyone have like a diagram for all the hoses and the wiring for when the mpfi is installed
Old Dec 29, 2010 | 08:45 AM
Photogenic
Loved
No one has pics...just self drawn pictures or things similar. I would love a pic. Im trying to get everything together or at least what im gonna need for the swap. SO from everyones comment am i correct that if I use the dx original harness I just need to add some connectors and wires where-as the d16z6 im installings' harness would only need additional wires...? Right or wrong. And the main thing is that i could use both?
Old Dec 29, 2010 | 10:52 AM
Clipsed's Avatar
Gu use your stock dx harness and add whatever wires you need.
civicboy420
21
Aug 28, 2011 05:58 PM
blue91EF
Mar 3, 2011 08:46 PM
oh-yeahcrx
Nov 4, 2006 09:37 PM
geoff19crx
May 31, 2003 08:19 AM
OldSchoolHatch
May 28, 2002 09:54 PM
