Short Ram Intake
Hey I own a 1993 civic si with a D16Z. I just bought a short ram intake to replace the stock rubber one. I have came across a problem while putting it on. The intake fits properly, but the connecting hose that connects to the intake is to big, and will not fit into the intake. I was wondering am I able to cut the stock metal connector and replace it with a rubber tube and put the other tube end over the intake to make a seal.
If the hose too big, can't you just put a clamp over it and squeeze it to fit?
Yeah, get a pic up. Sounds like you might be refering to the breather tube...
Get a picture of both pieces that you are trying to connect
i just put the original tubing to one side and replace it with a silicon hose to go from valve cover to intake arm. And no you cannot cut it entirely off otherwise you will get collant pissing out eveywhere
If I remember right, I ended up getting rid of the metal connector altogether and just replaced the coolant hose with a longer one... then I ran a silicone hose from the breather tube to the intake.
