Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
95-98 Odyssey - REAR Upper Ball Joint (Can't Find)
Old Dec 27, 2010 | 04:05 PM
gentek1145's Avatar
Icon3 95-98 Odyssey - REAR Upper Ball Joint (Can't Find)
Hello,
Looking for some input on where I can source a replacement OEM or similar REAR UPPER ball joint for the control arm. Anyone know if it is the same joint as the front upper joint or same as another model (Accord / prelude)? Honda will only sell the control arm as a whole, not the joint separately, however, I can find the front upper joints separate but that's about it.
Help!?
Old Dec 27, 2010 | 09:52 PM
BracedEunos's Avatar
Default Re: 95-98 Odyssey - REAR Upper Ball Joint (Can't Find)
Quoted from Overboostin from over on the Odyclub forum.
Originally posted by overboostin
as for rear ball joints , 97-00 preludes use the rear upper balljoint on its front, and they sell adj baljoints for the front on preludes, so they should work on our rear, sorry had alot of time at work to cross numbers. iv got some lude front adj balljoints coming, will let u know how it turns out.
And it is confirmed that the Prelude front balljoints work on the rear of the Ody. Expect to pay around $80-$100 for a adjustable Moog ball joint.
Old Dec 28, 2010 | 05:58 PM
gentek1145's Avatar
Is it noted for the SH or regular Prelude models? (Front Upper correct?)
Old Dec 29, 2010 | 10:19 AM
gentek1145's Avatar
Any advice on replacing the rear upper control arm bushings? (Rubber insert) Honda doesn't list it on the part catalog.
Old Dec 29, 2010 | 09:08 PM
AFAIK Any prelude from that gen will work on the ball joint.
Unsure on the control arm bushing.
Old Jan 1, 2011 | 06:30 AM
gentek1145's Avatar
JUST CHECKED, 92-95/97-01 Prelude Front upper ball joint will NOT work on the odyssey rear upper control arm....Way too big of a nut on the top (wont' fit into the ball joint hole in the arm)....
Old Jan 1, 2011 | 06:50 AM
Check up at odyclub then. A few of the devoted users are using that setup.
Old Jan 5, 2011 | 07:32 PM
overboostin's Avatar
i had the set up on my van and so did some others .. stock upper control arm .
not sure on the 92-96 same as 97-01 prelude , i used 97 prelude base front upper balljoints
when i looked it up the 92-96 was the same for accords and preludes but diffrent than 97+ preludes
are you putting this on the oem one or those aftermarket ones you picked up ?
if you just wanted stock ones napa auto parts sells it
Old Jan 16, 2011 | 03:53 PM
Stridge67's Avatar
I've replaced my rear uppers with 1 degree ball joints from Mevotech part #pk90490 and is the same for the front
Old Jan 17, 2011 | 05:17 AM
gentek1145's Avatar
Thanks, I was actually needing replacement joints for my Cusco camber arms and they are different than OEM but look the same.
acanby
May 23, 2011 11:35 AM
Decatur Racer
Suspension & Brakes
Apr 10, 2009 08:53 PM
Thrashed Civic
Jul 23, 2007 05:55 PM
ugotdubbz
Nov 7, 2006 03:20 PM
