Severe Oil Leak
Old Dec 26, 2010 | 11:26 PM
gandalf's Avatar
Default Severe Oil Leak
Hey Guys, (and found out that there are Ladies out here), I have a 92 Accord Ex, and I knew about a minor oil leak from the oil pan gasket every 800-1k miles. Moderate weather...but in the last 2 weeks the temp has dropped to 9 degrees and my oil issues have gotten worse. Today I used one quart to go to work and one to come back (21 Miles one way) I can't see how the temp would affect the Oil...
Any Ideas?
Thanks Much,
G
Old Dec 27, 2010 | 05:51 PM
brakedrum's Avatar
Default Re: Severe Oil Leak
Cold temperatures makes seals shrink, creating bigger gaps. The cold can also shrink poor-quality round seals, such as the crank seal, enough to completely unseat them.
Old Dec 27, 2010 | 06:06 PM
Toyota00's Avatar
I would just replace the gasket if you have the opportunity to.
Old Dec 27, 2010 | 06:10 PM
AndyD's Avatar
Are you sure it's only leaking from the oil pan? I believe the 4th Gen Accords also suffered from the balance shaft seal issue.
I would get it looked at immediately. You could ruin your engine! The oil pan gasket is so easy to change, too.
Old Dec 28, 2010 | 04:18 PM
361 accord's Avatar
9 degrees, holy crap!!!
theres your problem nothing is meant to exist that cold
Old Dec 28, 2010 | 05:44 PM
Toyota00's Avatar
x2 lol
Old Dec 30, 2010 | 02:41 PM
gandalf's Avatar
I found the oil leak, it's not where I thought. I replaced the oil pan gasket and did an oil change, cranked her up and found the actual leak. Directly below the oil filter is a "teat" if you will, and that's where the leak is. I've gone thru the service manual and can't figure out it's function...other than to leak oil. Is there a sure fire way to plug this hole?
Thanks Much,
G
Old Dec 31, 2010 | 12:19 AM
nus_dogg's Avatar
Wait, can you provide pictures if possible?
Old Dec 31, 2010 | 06:10 PM
mkrieger500's Avatar
Mine had this issue. Get a retainer for the front balance shaft seal from Honda and a new seal. Don't let it go too long. Mine lost all 4 quarts in a few min. Luckily I caught it and shut the car off!
Old Dec 31, 2010 | 10:00 PM
gandalf's Avatar
I found out where it's leaking...I hope the picture shows up in this post. it's directly below the oil filter. As long as I'm going forward the oil light stays off but when I use the brake to slow down...it comes on and flashes.
Thanks Much,
G
I've tried to copy the pic out of the Service manual (PDF) and paste it here but it's not working.
Ideas?
Old Dec 31, 2010 | 10:30 PM
GSRpoweredEJ's Avatar
Tear her apart and look for the problem. Must be a worn gasket somewhere.
Old Jan 1, 2011 | 02:16 AM
holmesnmanny's Avatar
Find a way of getting a pic uploaded.
Old Jan 2, 2011 | 09:40 PM
gandalf's Avatar
Here we go...in the picture, the bottom arrow, pointing at the oil cooler passes right thru where the leak is
The picture is called Leak.pdf and it gave no error when I attached it. I don't see it but hopefully it went thru.
Thanks,
G
File Type: pdf
Old Jan 2, 2011 | 10:50 PM
Targa250R's Avatar
be professional
The oil cooler O-ring is bad. It's a common point for a high-volume oil leak, especially in cold weather.
You'll need part number 91316-PE7-730. Remove the oil filter and the oil cooler to replace the O-ring.
Old Jan 2, 2011 | 11:36 PM
gandalf's Avatar
I'll look at that...but I saw oil pouring out of that hole...when I cranked her up. Might be a pressure malfunction. I saw another thread recently that mentioned, I can't recall it...any idea what the hole does?
Thanks,
G
Ralph3991
Jan 11, 2013 07:18 PM
JimmyM86
Honda Civic (2001 - 2005)
May 11, 2008 01:26 PM
Teglessb18
Oct 21, 2005 03:06 PM
acketon
Mar 15, 2004 08:50 PM
jwiedmayer
Nov 30, 2001 07:02 AM
