Suspension & Brakes Theory, alignment, spring rates....
coil overs vs lowering springs
Old Dec 26, 2010 | 11:05 PM
92db2gs-r's Avatar
Default coil overs vs lowering springs
im thinkin bout goin back to coil overs... what u guys think performance, comfort, and handeling wise?
Old Dec 27, 2010 | 05:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: coil overs vs lowering springs
Be more specific with your question. What is it you want to know exactly?
Old Dec 27, 2010 | 05:25 AM
Libertariat's Avatar
Ek Forever y0!
Handling and comfort aren't dependent on whether or not you have a coilover sleeve or a spring. The spring rate of either item will dictate your comfort and performance.
Coilover sleeve: You get a choice in ride height, and with some quality coilover sleeves you get an option of spring rates.
Springs: It is seldom you get an option for rates, the market for name-brand springs is a little larger than coilover sleeves. You can essentially pick your rates by picking the right brand.
I recommend coilovers for the mere fact that you can make the driver's side a tad higher than the passengers so the car is better tuned/aligned for your weight in the car. My driver's side is about 1/8" higher than the passengers. I don't think any spring manufacturer tries to account for driver weight.
Vague post is vague. If you'd like more help you need to be more specific about the use of your car, your budget, etc.
Old Dec 27, 2010 | 08:28 AM
FlewByU352's Avatar
I hate how lowering springs make the drop so un even and you cannot corner balance. Because my gas tank is on the drivers side my car sits much lower on that side then when I get in it, it appears as if a fat *** is driving.
Old Dec 27, 2010 | 10:50 AM
92db2gs-r's Avatar
I got tein springs and im thinkin bout goin to ground controls because my car is 1/2" lower on the drivers side but wat i was wondering is will i catch better traction and take corners better with coil overs? My teins are super soft but they are so comfortable.
Old Dec 27, 2010 | 11:05 AM
Ek Forever y0!
Soft = comfortable
Hard = performance with less comfort.
Stiffer does typically mean better traction and better handling.
It's not a matter of whether or not you have coilovers. What does matter are the spring rates.
slow&low
Suspension & Brakes
34
Aug 10, 2013 02:35 PM
pmp
10
Jun 11, 2011 02:58 PM
Ready4lyf
Suspension & Brakes
17
Apr 23, 2011 08:37 AM
wEaK Squad *ATL*
Suspension & Brakes
Apr 25, 2010 07:32 PM
