Alignment Problems
Hi every body,my 2004 Accord 2dr 6spd six cyl.seems to have more positive camber on L H wheel (front)than on the RH wheel,, therefore turns better to the left than to the right.This cannot be adjusted,any ideas what could be bent? all I have hit is potholes. thanks, JJ
What does the camber measure? Does the car pull?
all it takes is potholes to bend/break parts. ive smashes rims into ovals and bent LCAs. as stated have it put on an alignment rack to see how much outta spec it is. there is no factory adjustment for camber so im assuming you have some bent suspension parts
Hi everybody,thanks for the comments and suggestions, just found out the pivot and steering knuckle are bent, according to another alignment rack scientist (he did take a lot of time )anyway it sounds expensive, but it's got to be fixed.Thanks again, JJS
yooo i got a 97 ek she pullls tought to the right slight clunk from like 2 grand to 4 grand hurd it could be a wheel bearing someone help! any suggestions would be appricieated.
GoLowDrew
Mar 25, 2002 09:02 AM
