Whine Noise - question
Old Dec 25, 2010 | 02:06 PM
99SlammedCivic's Avatar
Snipper Snapper
Default Whine Noise - question
Upon taking off, there is a whine noise coming from the Type R.
It doesn't sound like it is from the motor but rather transmission. It goes away after about 3k rpms - if I"m cruising 50 or so, it goes away.
Car has an aftermarket clutch/flywheel setup .
You can hear it from outside of the car - what could this be?
Old Dec 25, 2010 | 02:11 PM
tofu1413's Avatar
Default Re: Whine Noise - question
i know my release bearing is causing similar problems..
it sounds like the car is dragging chains around @ lower rpms..
Old Dec 25, 2010 | 02:17 PM
itr#1334's Avatar
You sure its not the intake? Mine wines from 2-4k and its the intake.
Old Dec 26, 2010 | 08:41 AM
R boy fresh's Avatar
sounds like a clutch release bearing issue... hish
Old Dec 26, 2010 | 03:51 PM
94rs-turbo's Avatar
not your AAARRRRR so just buy it lol
Old Dec 28, 2010 | 09:13 AM
Quick99Si's Avatar
Is it possible that you're confusing "whining" with a "whir" type of noise. I've seen several ITR's make similar noises caused by worn input shaft bearings. Anyway, this might help narrow it down a bit:
If you're not a woman, get the car moving about 10-15mph in 1st gear, push the clutch pedal all the way in, and kill the ignition letting the car roll with the engine off and trans in gear. Do you still hear the same noise?
Old Dec 30, 2010 | 05:08 AM
440whpdailydr's Avatar
My vote is for the imput shaft bearing as well. Has it been getting worse?
Old Dec 30, 2010 | 09:18 AM
cannan's Avatar
Like what Quick99SI said above....do you hear the noise all the time or only when in gear? If you were to push in the clutch does the noise go away? If its the input shaft it should go away when you depress the clutch.
Otherwise my guess would be wheel bearings.
Old Dec 30, 2010 | 07:45 PM
Quick99Si's Avatar
Wheels bearings will usually make more of a pulsating noise like in this video
http://www.youtube.com/watch?v=ocaUL...er_profilepage
Old Dec 31, 2010 | 09:58 AM
cmdr430's Avatar
What final drive is in the tranny?
o.e., ats, mfactory, etc?
Old Jan 2, 2011 | 03:07 PM
Snipper Snapper
I think you & 440whpdailydr hit it on the money -
Throw out bearing / input shaft bearing is what I was told by a mechanic -
The noise goes away at idle with my foot pushed down on the clutch pedal.
Thanks guys
Old Jan 2, 2011 | 05:15 PM
CRX_RR's Avatar
that whine noise is from you not taking some good care. TLC should we say
Old Jan 2, 2011 | 07:27 PM
Snipper Snapper
lol - its okay sweetie pie - it wasn't my car that I was asking about
Tking10
Transmission & Drivetrain
Sep 1, 2011 11:00 AM
usdmed9
May 17, 2011 10:46 AM
ufakeit
Sep 5, 2009 04:21 PM
BudMan
Aug 11, 2004 04:58 AM
Toadfart
Jan 13, 2004 08:16 PM
