Ready for the New Year ......... What you guys think !!!!!
suspension:
Skunk2 pro C coilovers
GSR front and rear brake conversion
ARP extended wheel studs front and rear
Interior:
GSR seats
Civic Type R instrument cluster
Removed rear seats
Exterior:
OEM Sir front lip
Skippworks bumper quick-release fasteners
Fiberglass MB race doors with Lexan windows
Custom body graphics
Engine:
B18c motor:
stock block with RS machine P30 pistons
stock rods
Type r water pump and oil pump
Drivetrain:
Stock GSR transmission
act 6 puck clutch and type r flywheel
Prothane mount inserts
Custom solid rear mount
DNR race ported b16a head
skunk2 valve springs, retainers and stage 2 cams
Skunk2 cam gears
Chrome valve cover
NGK spark plug wires
Skippworks modified intake manifold (blox pro series core)
Blox 68mm throttle body
b&m fuel regulator
walboro in tank fuel pump
Hytech replica headers with custom mounted oem heat shield
Aluminum race radiator
Skippworks ram air (through passenger side headlight) with polished aluminum velocity stack
Skippworks engine grounding kit
Power: 201hp @ DNR performance.
The car has attended every CMI race in 2010, and also IDRC @ Fontana.
The cars best time is a 12.8 (prior to all weight reduction and doors), and has well over 100 passes on the motor.* The car is totally streetable, and attends every bay area meet and car show.
The car was also in the Spocom show in 2010 (bay area)
Sponsors: DNR performance, Bay Bully Redz, Skippworks.com, R Garage
Interior:
GSR seats
Removed rear seats
Exterior:
OEM Sir front lip
Engine:
B18c motor:
stock rods
Drivetrain:
Skunk2 cam gears
Chrome valve cover
b&m fuel regulator
