anyone have the cam card for the Jun 3 camshafts?
Old Dec 24, 2010 | 08:19 PM
tempsohc's Avatar
Default anyone have the cam card for the Jun 3 camshafts?
in need of the cam card for the Jun 3's for B series. dont wanna put them at 0 cause my head and block have been significantly resurfaced and milled
Old Dec 25, 2010 | 06:54 AM
Racewerkz's Avatar
Default Re: anyone have the cam card for the Jun 3 camshafts?
go to the jun web site
Old Jan 2, 2011 | 08:54 AM
Padawan's Avatar
Darth ModerVader
What specific settings are you looking for recommendations on?
Old Sep 22, 2011 | 08:27 AM
tempsohc's Avatar
Hopefully mikeyspec can answer my question? Been going crazy looking for the degree settings!
Old Sep 22, 2011 | 12:54 PM
DartGuy25's Avatar
Man let me know too Please i havent degreed my juns yet either Thanks!
Old Sep 22, 2011 | 01:04 PM
DDTECH's Avatar
I'll get you the degree settings after work. I have them.
Old Sep 22, 2011 | 01:27 PM
tempsohc's Avatar
Thanks. ALso i pm'd you about the pro2's?! Also the degree settings are Jun recommended correct?
Old Sep 22, 2011 | 02:34 PM
DDTECH's Avatar
#1 (Pri) #2 (Mid) #3 (2nd) VC
Duration Lift Duration Lift Duration Lift
Type3 IN 60 (240) 6.5 76 (304) 12.0 63 (252) 9.0 0.17
EX 63 (252) 8.7 76 (304) 11.5 60 (240) 6.2 0.19
Part# 1004M-H003 (INT)
- 1mm lift at 32° ABDC
- 110° lobe centre
- 1mm lift at 8° ATDC
Part# 1004M-H103 (EXH)
- 1mm lift at 8° BTDC
- 110° lobe centre
- 1mm lift at 32° BBDC
I ALSO have this from cheetah
Jun3 cam degree specs
degree peak open @ 20 thous:
Intake cam 12-17 deg BTDC with 20thous of lift
Exhaust cam 61 deg BBDC
Old Sep 22, 2011 | 04:58 PM
DartGuy25's Avatar
Cool thanks ALL MOTOR i really needed these specs bad!!
Old Sep 22, 2011 | 05:54 PM
tempsohc's Avatar
- 110° lobe centre
- 110° lobe centre
Correct me if i am wrong but centerline=peak lift
So peak lift should occur at 110 degrees crank right?
Old Sep 25, 2011 | 09:43 PM
tempsohc's Avatar
finally recieved the reply from Jun. This is what i got.
JUN Auto Mechanic3-1-7 Sekimachikita Nerimaku TokyoTel 81-3-3920-4165 Fax 81-3-3594-2689Sep 24
Dear Mr. *censored*
Thank you for your mail.
B-series type 3
1. Tappet clearance IN 0.17mm / EX 0.19mm
2. Take the center angle 110 degree from TDC at the primary lobe in eachintake exhaust cam.
Thank you,
So my question now is Center angle is peak lift. Which should occur at 110 degree's btdc, or atdc? and for which cam lobe am i degreeing? it says primary cam lobe meaing? Im confused.
Do i need to lock the vtec in place? do i just degree it using the non vtec lobes? how so? and which lobe is the primary i should be using> it seems they are off set a little. Idk
ALL motor: did you degree them in using the vtec lobe?
Old Sep 26, 2011 | 07:24 AM
DDTECH's Avatar
Dear Mr. *censored*
B-series type 3
Thank you,
yes, use peak lift.
Lock vtec. Use vtec lobe.
Old Sep 26, 2011 | 11:56 AM
tempsohc's Avatar
so what exactly did they mean by use primary lobe? i searched and primary lobe is the non v lobe correct? well i will lock the vtec in. St my lash to 0.
Thanks all motor for your patience with me!
Old Sep 26, 2011 | 02:29 PM
DDTECH's Avatar
I would use vtec lobe to degree in, if the primary does share the same centerlines then yea, you could use the primary lobes without locking vtec, but i'd just do it the normal way. That away you can also check your P2V and what not while vtec is locked. Better then guessing.
Old Sep 26, 2011 | 06:14 PM
tempsohc's Avatar
So if the degree settings you gave me are for the primary or the vtec lobes? if those are juns recommendations wouldnt that be the settings for the primary lobes? Just kinda sketchy on how this works. You've personally degree'd the jun 3's using those settings on the vtec lobe?
Old Sep 27, 2011 | 06:06 PM
tempsohc's Avatar
yes, use peak lift.
would i follow the same specs you gave me using the primary lobes? I am having a hard time decyphering the juns email and coming to a conclusion on how/where you got your specs from. help a brother out!
Old Sep 27, 2011 | 08:41 PM
DDTECH's Avatar
Yes, Use the center lines i gave you...I would follow the info i gave you, as its actual measurements.
Contact JUN, ask them if their primaries follow the same center lines as their vtec lobes, if so you will not have to lock vtec, however thats a shadtree way out.
Old Sep 30, 2011 | 03:09 PM
tempsohc's Avatar
help me out. im hella confused.
Your measurements are taken after 1mm of lift is achieved correct?
- 1mm lift at 32° ABDC (closing)
- 110° lobe centre
- 1mm lift at 8° ATDC(opening)
- 1mm lift at 8° BTDC(opening)
- 110° lobe centre
- 1mm lift at 32° BBDC(closing)
Lobe center is 110° on the degree wheel correct. peak lift occurs at 110° right?
So confused
Old Oct 16, 2011 | 06:11 PM
tempsohc's Avatar
finally got a chance to set this up. I ended up with +2I +1E
head decked .005 block decked .005 running a .018 headgasket. sound right?
Intake cam gear was advanced 1/2 tooth So TDC marks on the gears where off when i started.
Old Oct 16, 2011 | 06:30 PM
00Red_SiR's Avatar
All Motor Mentor
1/2 a tooth or half a degree advanced? Your measurements add up to about .020" height reduction which translates to 1/2 a degree correction required. Your cam gear final numbers sound about right and not out of whack.
Old Oct 16, 2011 | 11:36 PM
tempsohc's Avatar
well it seemed like the exhaust gear was perfectly level with the head and the exhaust line matched up to 1/2-1/8 of a tooth under the line on the intake gear(both cams at 0) thats the only way i could eliminate all the belt slack and get the gears to somewhat line up.
txenxo
Dec 26, 2008 07:02 PM
GrimLude
Nov 2, 2006 01:07 PM
lazyguy
Apr 16, 2002 10:18 AM
StinkyTofu
Feb 19, 2002 01:37 PM
