constant vtec
Old Dec 24, 2010 | 05:04 PM
mickb20z's Avatar
Default constant vtec
wat gains if any are got by constant vtec say like havin it on a switch
Old Dec 24, 2010 | 05:09 PM
skacoreimplore's Avatar
Default Re: constant vtec
TODA vtec killer cams?
Old Dec 24, 2010 | 05:11 PM
mickb20z's Avatar
it will be kinda the same job i was just searchin the net and see this can be done and woundered wat gains can be had ive buddyclub spec3+ cams and buddyclub valve train
Old Dec 24, 2010 | 06:26 PM
PyroProblem's Avatar
You will see no gains at all. You will lose bottom end, your car will be slower, and most likely barely idle unless you have some sort of engine management..
Youll probably find more info in the tech/misc forum. Id search there if I were you...
Old Dec 24, 2010 | 06:59 PM
mouab18c1's Avatar
Set vtec to 2k. LMAO
Old Dec 24, 2010 | 07:51 PM
fv8s's Avatar
You can't just lower VTEC without knowing what else it invloves. Do some research and you will see why this will not benefit you.
Old Dec 25, 2010 | 02:54 AM
mickb20z's Avatar
if i was to do it id be gettin it mapped and properly set up i jus wanna know would the be any benefits
Old Dec 25, 2010 | 06:30 AM
EHondaJDM's Avatar
Someone don't know what VTEC is....
He jus knows it be like BWAAAAH!
Lol
Merry christmas n holidays guys
Old Dec 25, 2010 | 07:44 AM
enemy no1's Avatar
LMAO!
Old Dec 25, 2010 | 09:19 AM
fv8s's Avatar
Lol
You too brother. Have a Happy VTEC-ish Christmas
Old Dec 25, 2010 | 09:55 AM
FlewByU352's Avatar
I had a friend that had VTEC set to 4k and he thought it was bad *** that it hit that low. I rode in the car and he did a 1-2-3-4 down the road. I said swing by my house real quick so I can grab my laptop. Did some street tuning and the sweet spot was 5500RPM. He did another 1-2-3-4 and goes holy **** thats way faster! You have to look at when your primary lobes stop making power, a lot of times switching to the bigger lobe lower in the RPM range will put a dip in the curve until it picks up more RPM. The point in tuning is to not have a dip in the curve at all if you can. To actually have a constant VTEC lobe you would have to lock the pins because remember it relies off oil pressure.
Old Dec 25, 2010 | 09:58 AM
HdeucedeuceA's Avatar
I'm sure there's not enough oil pressure at idle and lowering it anything below 3k probably isn't a good idea.
Old Dec 28, 2010 | 01:59 PM
EHondaJDM's Avatar
There are things you can do to raise the oil pressure, that's irrevelant.
Anyone who knows why vtec was made and how it works wouldn't eliminate it.
Why do you guys think ford, toyota, nissan, and other manufacturers are using it now too?
Old Dec 28, 2010 | 03:27 PM
SR20S13's Avatar
The reason to run vtec killer cams is so you can take out all the vtec parts so the valve train is lighter and you can rev higher and more reliable
Old Dec 28, 2010 | 04:54 PM
EHondaJDM's Avatar
They are only for race engines that spend most of their time above 5k
Old Dec 29, 2010 | 02:26 AM
mr_munro's Avatar
i have VTEC set at 3800, only because when i tuned it the idle cam stopped making power at that RPM, power delivery is a lot smoother and the lower end torque is very useful, only bad thing i can think of is the VTEC engagement barely noticable..in relation to OP thread, you will lose a substantial amount of power and torque, and probably have **** petrol usage..
Old Dec 29, 2010 | 05:30 AM
EHondaJDM's Avatar
Originally Posted by mr_munro
i have VTEC set at 3800, only because when i tuned it the idle cam stopped making power at that RPM, power delivery is a lot smoother and the lower end torque is very useful, only bad thing i can think of is the VTEC engagement barely noticable..in relation to OP thread, you will lose a substantial amount of power and talk, and probably have shift petrol usage..
What cam are you using?
did you check what your oil pressure is when vtec engages?
Old Dec 29, 2010 | 05:35 AM
Libertariat's Avatar
Ek Forever y0!
Old Dec 29, 2010 | 05:44 AM
mr_munro's Avatar
just my stock GSR cams and i have no idea about my oil pressure sorry
Old Dec 29, 2010 | 05:56 AM
EHondaJDM's Avatar
Your oil pressure is most likely low while vtec engages. And maybe im wrong but I don't think you should be losing power at 3800 on stock cams. Where did you tune it?
Old Dec 29, 2010 | 06:01 AM
mr_munro's Avatar
I can provide you the dyno print out before and after mods to show you the drop off in power at that RPM..i tuned it on a very reputable and professional dyno, the power curve is so smooth, virtually no down or up 'bumps' in power anywhere throughout the rpm range.
Old Dec 29, 2010 | 06:05 AM
EHondaJDM's Avatar
Hmmm what are your mods?
Old Dec 29, 2010 | 06:06 AM
mr_munro's Avatar
GSR motor - skunk2 IM, 65mm TB, RMF 4-1 header with a 2.5" exhaust
Walterronny
Apr 25, 2006 09:22 PM
7mile
38
Feb 15, 2006 06:59 PM
beandip
19
Dec 12, 2004 03:54 AM
jessevtec
Sep 24, 2003 12:00 PM
^jefs0ng
May 15, 2003 05:22 PM
