Slow CLutch leak??? wheres it going?
ok so about 7-8 months ago my clutch was really loose i checked the fluid and it was rly low, so i fixed it by bleeding and adding more fluid.....everything back to normal for awhile......until about a week ago it was loose again so right away i checked the fluid knowing that probably was the problem. and it was drained really low again. So now i need HT's help of where to look for a leak or suggestions of the problem.....Solve another problem for me honda-tech!!
take the rubber boot out of the slave cylinder and check if its wet...and look behind the clutch master under the dash..unless u have a leak in the lines those are the most common places for leaks....slave cylinder or master..
Most likely leaking behind the pedal into the cabin. If this is the case, it's time for a new MC. Easy install on these cars. Just hope you have a friend hand (as well as some patience) to bleed the darn thing...
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
ej1-usdm
Dec 5, 2007 04:03 AM
GraphiteMW
Mar 25, 2007 09:26 AM
