Engine is way out of timing, how do I safely fix this situation ?
Old Dec 24, 2010 | 04:14 PM
LdySheri's Avatar
Default How to replace rubber seal between intake manifold and thermostat housing
There is a small rubber seal which sits between the intake manifold and the thermostat housing, and I would like to replace this seal. How can I replace this seal if there is such a small gap between the intake manifold and the thermostat housing (when the thermostat housing bolts have been removed). There seems to be a half inch gap at the most, not enough room to get fingers into the gap and just not enough room to remove the old seal and put a new seal in and make sure it has seated itself properly.
E M Wynne
Jan 28, 2018 02:31 AM
maknes
Jun 18, 2014 06:36 PM
EF7
Apr 22, 2008 04:41 PM
jaydem7
Sep 5, 2007 06:10 PM
