newb build b20vtec questions
Old Dec 24, 2010 | 02:55 PM
yungkhmer's Avatar
Default newb build b20vtec questions
First off, i am a newb. This will be my first B-series HEAD build EVER. Please bare with me as i am still learning as i go. So any advice/criticism hate watever go ahead and do so as you please if it'll make you feel better.
My budget build will consist of:
95 GSR head
supertech valvespring
supertech retainers
brand new ITR valves
brand new OEM keepers
brand new OEM valve stem seals
blox HSL comp series camshafts
Pretty much all i know so far is knowing how to completely remove the whole valve train with proper tools and lapping the valve.
What i was going to do first, was send to my head to a local shop to get it hot tanked. When doing that, do i need to remove my rocker arms? i know i have to remove pretty much everything else but the rockers arms im a little confused about.
After i get it back all cleaned up, i was going to put the valve train back in myself. Now with using brand new oem ITR valve will i have any problems using them in my GSR head? will they fit right in with no problems after i lap the valves since they are oem?
Sorry guys if i don't make since please take into consideration that this is my FIRST build so any help guidance along the way would be gladly appreciated, thanks all!
Old Dec 24, 2010 | 03:29 PM
fv8s's Avatar
Default Re: newb build b20vtec questions
Yes you need to remove the rockers and the lost motion assemblies. The rockers can be pulled out by removing the two locking pins on the side of the head. After you pull the pin take out the allen key plugs and pull the rod out. Make sure to keep everything in order and put it back in the same way it came out.
Old Dec 24, 2010 | 03:56 PM
yungkhmer's Avatar
wait, am i suppose to lap before or after the hot tank?
Is there anything else I am missing? & with the ITR valves will they just drop in and work fine or do i need to do something special with the valves itself?
Old Dec 24, 2010 | 07:47 PM
fv8s's Avatar
The valves will work. You should lap the valves after the hot tanking is completed. I have a valve lapping tool you could buy if you do not have one.
Old Dec 25, 2010 | 12:35 PM
yungkhmer's Avatar
Thanks bro.
so just to clarify, i can install brand new in the package, ITR valves after lapping them with NO problems right?
should i do anything else to my head besides what i have stated?
btw merry christmas everyone! Dont drink & drive guys.
Old Dec 25, 2010 | 08:05 PM
fv8s's Avatar
- Yes you can install the new ITR valves, I suggest a 3 angle or back-cut but the lapping will work fine.
- Depending on your CR and setup I would choose a better cam (like a Skunk2)
- Too late on the drinking and driving
Old Dec 25, 2010 | 10:24 PM
UncleD's Avatar
You're not gonna be using the stock B20 pistons are you? What made you choose the HSL's?
Old Dec 26, 2010 | 06:50 AM
b20vtech's Avatar
i recommend getting a valve job done, most of these head valve seats are pitty anyways, unless a valve job was done not so long ago.
Old Dec 26, 2010 | 09:32 PM
.Manny.'s Avatar
Touching My Member
In other words...Boom!
Old Dec 27, 2010 | 12:46 AM
yungkhmer's Avatar
i thought about that... lol
BLOX HSL's because they were.. well free 99, so mind as well use it right?
piston wise, i was going RS machine ITR style 84mm pistons with eagle rods and arp rod bolts.
good enough to NOT go boom?
Old Dec 27, 2010 | 06:55 AM
vtechjunkie's Avatar
For the same price you can get the 12:1's from rs machines and have a bit more potential. I would go that route, although, you will be fine either way with some proper tuning. Take some extra money and get the valve job done, I'd hate to get a motor all put together and have it smoke, or something stupid just because I didn't want to spend another $300. Should be a fun drive when it's finished. Keep us posted.
Old Dec 27, 2010 | 12:45 PM
civic00sir.'s Avatar
i have heard that the valve spring keepers dont need to be replaced, but idk...not 100% sure
Old Dec 27, 2010 | 10:54 PM
.Manny.'s Avatar
Touching My Member
you'll be fine then. the stock b20 pistons don't have the valve relief clearance to run big cams like that
Old Dec 28, 2010 | 03:33 AM
yungkhmer's Avatar
BUT...
The thing is, i wont be building the block til later down the road, probably within 6 months or more from now. I wont be taking it up that high, 7k max for now. As long as it'll run and not die out on me i wont care too much. 7k sounds pretty safe for a built head stock block. cant i just notch the valve reliefs on top of the stock pistons for now?
Old Dec 28, 2010 | 06:40 AM
b20vtech's Avatar
BUT...
u can, just make sure to triple check your clearences.
Old Dec 28, 2010 | 05:06 PM
yungkhmer's Avatar
are you referring to P2V clearance?
Old Dec 29, 2010 | 08:46 PM
yungkhmer's Avatar
And i will be getting a tune with this setup, a mild tune that is just to get everything running okay.
Boosted_90Teg
Sep 10, 2011 06:30 PM
blackakgsr
Mar 25, 2009 07:35 PM
blackakgsr
Mar 23, 2009 12:08 PM
topspeed86
Nov 29, 2005 03:20 PM
caspers_hatch
Jun 6, 2005 02:09 AM
