B18c1??
Old Dec 24, 2010 | 01:29 PM
FunForFree33's Avatar
Default B18c1??
Hi I have a Obd1 Gsr b18c1 I have been looking for a body for. I have engine trans ecu and axles. My friend has a 97 accord he doesn't want. The body is in nice shape it's a ex with vtec. I was wondering if I could put my motor in there and if so how hard would it be and what would I need. His car is obd2
Old Dec 24, 2010 | 06:53 PM
GhostAccord's Avatar
Default Re: B18c1??
Not too many B swapped accords around. I would think that you would require custom engine and trans mounts. Along with custom axles and hub assemblies. The engine will fit easy enough it's getting everything to bolt up in line that may require the extra work.
Other than that the wiring would be the same sort of wiring issues as swapping an OBD1 engine into any other OBD2 chassis.
Like I said, swapping a B series into an Accord isn't a common swap. Therefore specific details will be somewhat harder to find.
Hope some one else may have some more specific info for you.
Good luck
Eric Byrd
Jul 9, 2018 06:13 PM
cptbarkey
Aug 22, 2013 10:23 AM
MTracing
Mar 29, 2012 01:11 PM
Stakhov
Feb 27, 2010 10:36 PM
