NSX Caliper info, need help FAST
Old Sep 23, 2002 | 01:07 PM
TDRacing's Avatar
Default NSX Caliper info, need help FAST
I am looking into an NSX caliper upgrade on the R. I am looking into this as a alternative to the Spoon calipers. I would like to ask some questions to see if this is a worthwhile upgrade.
1-what calipers am i looking for? which years did they come on NSXs?
2-where can i get them, from a wrecker, from honda?
3-will i need to rebuild the calipers?
4-what is involved when installing them?
5-how much will this cost approximately?
6-when comparing them to the Spoons, how do they stack up?
If i do go through with this, I am going to need to finish it this week, so i need the info fast. thanks a lot.
Old Sep 23, 2002 | 01:15 PM
TDRacing's Avatar
Default Re: NSX Caliper info, need help FAST (TDRacing)
I have already done a search, and i couldn't find the answers to all my questions. Just so you guys dont flame me too hard.
Old Sep 23, 2002 | 01:21 PM
Big Phat R's Avatar
1. 91-96 caliper
2. wrecker, ebay or honda-tech.com classifieds
3. rebuilding is recommended unless they are brand new
4. bolt on - you should use thicker rotors though - i.e. 28mm instead of 23 mm
5. cost depends on purchase price of calipers - I've seen them for 250USD - with rebuilding/refinishing/painted/new seals/new rotors probably 600-800 CDN.
6. pad size is the same as the spoons (i.e. stock). BUT they use thicker rotors which will act as a larger heat sink - so fade resistance will be better. the NSX calipers are 2 piston vs 4 piston for the Spoons. The Spoon ARE WAY LIGHTER though at the expense of NOT fitting under a lot of 15" rims. The Spoons fit under OEM rims - but just barely.
There is no way in hell you can do this in a week.
There is a place in Seattle area that caters to NSX's and S2000s whose name escapes me right now - that guy had a set of calipers for sale (check the classifieds).
Old Sep 23, 2002 | 01:26 PM
Cosworth's Avatar
Default Re: NSX Caliper info, need help FAST (Big Phat R)
I think http://www.scienceofspeed.com/main.htm is the one you're looking for... maybe not.
Old Sep 23, 2002 | 01:27 PM
ZygSpeed's Avatar
So, is this going on a CRX?
Old Sep 23, 2002 | 01:34 PM
Big Phat R's Avatar
Default Re: NSX Caliper info, need help FAST (Cosworth)
bingo
Old Sep 23, 2002 | 07:23 PM
TDRacing's Avatar
Default Re: NSX Caliper info, need help FAST (Zygspeed)
no, these are going onto a race Type R
Old Sep 23, 2002 | 07:27 PM
migs's Avatar
https://honda-tech.com/zerothread?id=239844
Old Sep 23, 2002 | 07:41 PM
1GreyTeg's Avatar
Default Re: NSX Caliper info, need help FAST (Migs)
Thats the exact post I was thinking of, and also remember a few others but, I'm sure he will find them if he rephrases or changes his wording for the search.
A.
PS what race series is it for?
Old Sep 23, 2002 | 09:00 PM
TDRacing's Avatar
Default Re: NSX Caliper info, need help FAST (1GreyTeg)
[QUOTE
[/QUOTE]
it's for the westcoast challenge, up at mission raceways in Vancouver.
rollercosta123
Jan 11, 2007 04:03 PM
crj_lll
Mar 31, 2005 05:06 AM
Takashi1978
Dec 21, 2004 06:03 AM
modjunky
Oct 3, 2002 04:42 AM
