Suspension & Brakes Theory, alignment, spring rates....
Adding camber kit, will it change toe?
Old Dec 23, 2010 | 10:24 PM
TOO MUCH TORQUE's Avatar
Default Adding camber kit, will it change toe?
Im planning on installing my front and rear camber kits tomorrow, but was wondering if the TOE will change if i install camber kits. I just had my toe adjusted to 0 degrees on all the corners and didnt want to get another alignment if toe won't change if i add camber kits.
Old Dec 23, 2010 | 10:33 PM
Tyson's Avatar
Default Re: Adding camber kit, will it change toe?
absolutely. camber changes toe.
Old Dec 24, 2010 | 01:16 PM
racebum's Avatar
you should just buy the lifetime alignment at firestone. not only should you align your car after this, you should align it once a year. i actually do mine when i switch from summer to winter tires and again winter to summer.
crazy part is the setting change even in such a short period. the main reason i do this is front toe out. i run near zero on snow tires and always toe out summer tires. my snow tires are .01 out each side in the front and .05 in each side in the back. on summer tires the fronts are out around .04 each side
Old Dec 24, 2010 | 02:44 PM
98civdx's Avatar
Master Detailer
Deffinetly get the lifetime alignment, I just got mine last night
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
Dutty D
Suspension & Brakes
Mar 27, 2007 05:53 PM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
todds94teg
Sep 5, 2003 06:14 AM
spork sport
19
Mar 12, 2002 09:02 PM
